Question about Insignia D300a PC Desktop
Recovery disk needed
Computer wont boot-up, message says "reboot and select proper boot device or insert media in selected boot device" any advice?
  • 550 Answers
Reboot
on reboot, enter BIOS setup, F1 Esc, whatever the prompts say
and change the boot sequence to a valid drive.
This may not work since you did not say what occurred to __kup the boot sequence
Posted on Sep 20, 2008
  • 3 Answers
Maybe a loose connection with your hard drive.
Posted on Sep 24, 2008
My pc wont boot. All i get is " reboot and select proper boot device or insert boot media in selected boot device and press a key"
This can happen if you have non-bootable media in the default boot device (i.e., you have a CD in the CD/DVD drive and that drive is listed as the default boot device in your system's BIOS). More often (on newer systems), a failed hard drive will also produce this message.
If you have bootable media (the Windows install CD is one example), you should try to boot to it and see if you can read your hard drive.
Jan 20, 2014 | Computers & Internet
I have an hp pavilion p6110f pc and this message (reboot and select proper boot device or insert boot media in selected boot device and press a key) keeps coming up every time iI power the computer on. All...
Hi... try to hit F2 or F10 to enter bios setup and see drive menu if there is no HDD drive this mean your hard drive fail or select the 0 HDD as first boot.
Feb 04, 2013 | Computers & Internet
AMD Phenom X4 9500 quad-core LX6200-01 reboot problem
Hi to fix this problem go to bios settings and there select the hard drive on witch you've got system files then save and reboot. If you need more help let me know.
Sep 22, 2012 | Computers & Internet
Replaced hard drive and am getting a "Reboot and
Hi seqhdha,
The reason why you're receiving that meesage is the system is not detecting any bootable device on the computer or it is boot from a media that is not bootable (CD/DVD/USB). To fix this problem if you already installed the Operating System you can change boot priority setting and select the Hard Drive as the First Boot Device however, if you havent install the Operating System you need to select the CDROM as the First Boot Device and insert the Windows Installer.
Here are the steps on how to access the BIOS Page.
1. Restart the computer and while it is booting tap DELETE button.
2. On the Bios page look for the BOOT tab then set the priority to either Hard Disk or CDROM depends if you already installed the OS or not.
3. Follow the instruction on how to install the Operating System
4. Rate me if this helps so i can help others.
Thanls for using Fixya.
Jan 31, 2011 | Gateway 550GR PC Desktop
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
When I turn it on it says Reboot and select proper boot device or Insert boot media in selected boot device and press a key.
Please verify if you don;t have a floppy disk in your drive. If you don't then you have to verify in BIOS if is selected proper boot device - HDD.
If everything is set then you have problem with your hard disk, must check and install new operating system.
Feb 24, 2010 | E-Machines eMachines Desktop PC
My pc crashed and on restart it asks for me to reboot and select proper boot device OR insert boot media in selected boot device and press a key- I don't have the boot media c d and can no longer get
Listed below is link to HP drivers page for M270. The recovery Windows Media Center CD is no longer availabe for purchase. If you have a license copy of Windows XP you can install then download remaing drivers from link listed below:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=339679
Apr 29, 2009 | HP Computers & Internet
Can not reboot
Try tapping F8 at start up and try booting in safe mode...If this fails you will need to reinstall your OS.
Oct 17, 2008 | Insignia D300a PC Desktop
Insignia D300a PC Desktop Logo
655 people viewed this question
Top Insignia Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
