I need the wiring components to hook to a comp pc
    Problem Solver:
  • 19 Answers
You might find the solution at this blog: www.audioholicblog.com - they provide many wiring solutions and have lots of information.
Hopefully this helps!
Posted on Sep 20, 2008
My comp won't boot
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Oct 03, 2012 | Compaq Presario S6300NX PC Desktop
Power cable at rear of sony vaio pcv desktop sparking and not starting up
Stop using it. Bring it to a repair shop ASAP. You need your PSU replaced and if you keep using it you'll need your motherboard replaced as well. In fact if you keep using it you could burn all of your internal components out.
Jun 09, 2012 | Sony VAIO PCV-V200G PC Desktop
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
The sound isnt working i opened the comp up & 3 wires are unhooked
there is marking in each wire which pin need to be inserted??
Sep 13, 2010 | E-Machines W3107 (RBW3107) PC Desktop
Emachine D2880 no power clarification
your getting power to your PSU, via the green light on your mobo.
verify the PSU has a green light(most emachines do)
it sort of sounds stupid but, check the connection of the cable coming from the front of the case(the wires that connect to the mobo to the power button on the outside of the case.
if all else fails, take the pc out of the case.. put all components on a static free bag and start to rebuild your PC(without a case)
...this will rule out a short on the PC case, and faulty wiring from the case...
pretty much sounds like you've been through almost every step except replacing the PSU(you just said you tested/but your getting power to the PSU)
hope some of this helped
Sep 04, 2009 | E-Machines eMachines Desktop PC
Hp pavilion 764c wire diagrams
Take a picture of the inside of your computer and put it up on the website with the wire connectors that need to be connected. The connecting wires should be in four groups. 1. The power supply connectors. These connectors will supply power to to all the power using components not supplied power by the motherboard itself. 2 The connections to the other components in your system like the dvd/cd player and the harddrive and floppy drive.3. The motherboard connections for the case. The power switch connector andreset switchconnector. The power led and theharddrive activity light.The USB connector and the audio connector.The fan connections like the cpu fan and other fan only connectors found on the motherboard.The external fans ( Fans that need to be connected to the power supply).Most of these connections are labeled on the motherboard. The case connectors also should be labeled for the correct connection. The best way to find the answers to this hook-up, may be to call HP pavilion with your computer make and model number,motherboard model number including revisions number. Computer made by big manufacturers tend to have may revisions and the only way to make sure your are getting a correct hook-up to the motherboard is call them for assistance.Especially if the motherboard and case labels are not present or so small that they cannot be read.Hope this helps you with your problem.
May 16, 2009 | HP Computers & Internet
EMACHINE T6534 COMP. WANT BOOT . TRYING TO CHANGE V-CARDS
This could be a few things though if you have already checked the memory and HD. The next thing I would tell you is that you should check the cpu. Also make sure that everything in the BIOS is set to the default settings when you start it.
Feb 04, 2009 | eMachines T6534 PC Desktop
I have a laptop comp i just got a desk top comp i have embarq broadband internet which comp do i pit the cd into to install and which comp do i hook up the embarq box to?
It sounds as though you will need to get router to allow the sharing of the Internet between the two computers. Using a router makes it much easier to share an Internet connection between multiple computers. You would connect the Embarq box to the router on the WAN port, and then connect your computers to the LAN ports of the router. You may also want to get a wireless router in the event your laptop has a Wi-Fi connection.
Oct 06, 2008 | Computers & Internet
D-link hook-up
? Plug the router into comp, plug modem into router, plug comp into router, install cd for d-link router and that's it.
Sep 25, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
