Hooking up a klh PSW8-100 sub wofer
Need to know how to hook this up to a JVC RX-6500 v
  • chasmaniac Sep 21, 2008
    I found the site needed Thanx.
    Problem Solver:
  • 19 Answers
Hey you might find a solution on this audio and wiring blog: www.audioholicblog.com -- it has a blog about wiring your home audio system and the cables that you will need.
Hopefully this helps! Good Luck!
Dannyboy!
Posted on Sep 20, 2008
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
Trying to hook up a KLH sub woofer, S100ETH, PSW8-100 to a VCR reciever. Reciever has sub woofer connection but does not works on the KLH sub woofer. What is the problem ?
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Jan 06, 2015 | KLH Audio Players & Recorders
How can I hook up my jvc rx-6018v to a gemini xga-2000 amplifier?
you can do it a couple of different ways, depending on what you're trying to do with your set-up.if you're trying to do something different than what I describe here, add a comment.
for independent volume control (each unit contols volume to a set of speakers independent of each other) use the rca 'tape' out of the jvc into the rca inputs on the back of the gemini.this puts a stereo signal from the jvc to the gemini. if you want your gemini to power your subs, get an rca y-splitter (single female to double male) and a single rca cable, hook single rca cable to sub out of jvc, connect y-splitter to gemini rca inputs, and single rca to y-splitter.
Mar 05, 2013 | JVC RX-6018V Receiver
How do i hook up a sub-woofer to jvc rx-6040?
Any old subwoofer or is there a specific one? It's manual might give some clues.
Register and download the JVC RX-6040 manual for free at audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/jvc/jvc_rx_rx6040b.html
May 14, 2011 | JVC RX-6040 Receiver
My KLH subwoofer (model ASW8-120B) has stopped working and emits only a low-pitched hum.. I have tried hooking it up using the ''high-level'' 2-wire inputs as well as the ''low level'' RCA plug inputs....
It's unlikely that you can find a shop to repair it for less than the replacement cost ($75ish for a comparable KLH or Sony sub)
If you're up for doing your own soldering, here's a solution for the same problem with the same amp.
If this helps, please hit the "thumbs up" for me!
Jun 26, 2010 | KLH ASW10-120 Subwoofer
Can you hook a separate subwoofer to a JVS RX-552V? I thought I remembered a connection setting somewhere.
not that i know of i tried there is no output for a sub but if u figure it out let me know cack34@hotmail.com
Nov 22, 2009 | JVC RX-552V Receiver
About technice sa-dx930
The one plug on the back of the receiver is an rca-type plug and is designed to be connected to a powered sub, which would also have an rca-type input. Even if you connected it, this output carries a line level signal and is not powerful enough to drive a speaker. If your sub has 2 connectors (same as a normal speaker) then you have an unpowered or passive subwoofer. You would either need a powered sub, or to use an external amplifier of some sort...then the sub output from your current receiver would go into the external amp...and the amp connected to the passive sub.
Hope this helps.
Mar 30, 2008 | Technics SA-DX930 Receiver
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
SONY STR-DG510 Sub woofer does not work
You will need a powered sub because your receiver does not amplify in the sub output.
Jan 21, 2008 | JVC RX-554V Receiver
JVC RX-809V
Go to the following website www.servicemanuals.net where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
422 people viewed this question
 Grubhead
Grubhead
