My air-o-swiss 7142 humidifier keeps giving me the empty indicator light to signify no water in the unit even though the base and the tank are full. If I try to reset it comes on for seconds and then shuts off again as if it's empty. Not sure where the problem is coming from...
Leaking. The white plastic circular ring in the base unit is cracked. This is part of the...
(More)
Leaking. The white plastic circular ring in the base unit is cracked. This is part of the ********/evaporator unit. How can I get another repair part/unit? AOS does not list internal parts.
When if fill the water tank with water and place it on the base the base fills up and leaks between...
(More)
When if fill the water tank with water and place it on the base the base fills up and leaks between the base and the water tank.
i pushed the button, the signal shows the heat feature on, but the heat is still the exact same temp...
(More)
i pushed the button, the signal shows the heat feature on, but the heat is still the exact same temp as when it is off. it's cooling my room. and the percentage is still at 25% even though its been on for 2 hours..?
is this machine worth the extra money for these features if they don't work? or am i doing something wrong?
