Question about HP Photosmart 735 Digital Camera
Can not take photos screen will say flash is charging
My hp photosmart 735 will stay on charging flash while pushing on button.
and stay on can not take photos, it sounds like what pfb911 incountered with his 735 camera
  • sestrada2292 Sep 30, 2008
    I am having the same problem. Is there any way to solve this? Please help
Yea this is happening with me also
Posted on Oct 09, 2008
Photosmart 735 Digital Camera: how do I set the HPphotosmart 735 to display the d...
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
May 18, 2010 | HP Photosmart 735 Digital Camera
Constant Charging Flash HP Photosmart R927 digital camera
First I'd try turning the flash off, a manual option on nearly all camera's. Take a couple of photo's without flash, and turn the camera off and on a couple of times then turn the flash back on to auto.
If that doesn't resolve the problem, I suggest going to the HP website, follow links to support and/or downloads and see if there's a firmware upgrade for your camera.
Apr 26, 2010 | HP Photosmart R927 Digital Camera
Hp r927
Sounds like blown flash bulb.
Needs to be replaced.
Mar 19, 2009 | HP Photosmart 735 Digital Camera
E106 problem
hi my name is steve i am somewhat familiar with the 735 photosmart,2 things to fix this yourself is go to,look up your camera model and download your firmware your problem is error 106 your zoom lense is stuck plug your camera up to the usb and go on to youll find the firmware there follow the instructions after you download it the comp. will send the firmware right to your camera and presto your fixed your camera will opperate properly and your camera will have this up to date firmware its like a flaw with these and the firmware will fix it free of charge let me know if everthing is sucessful after and take care.
Oct 01, 2008 | HP Photosmart 735 Digital Camera
When using the flash, camera shows charging flash and freezes up the camera
I contacted HP tech, after trying several resets and other setting changes, I was informed that it would cost more to fix the camera then its worth - No longer under warnaty.
I can use the camera as long as I disable the flash.
Go out a buy a Canon, I did and its a lot better camera.
Aug 04, 2008 | HP Photosmart 735 Digital Camera
Continuous flash charge
Try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 23, 2008 | HP Photosmart 735 Digital Camera
Flash Will Not Operate
Flash doesn't operate from various reasons. Try to reset your camera if you find in the instructions manual a procedure like that. If it doesn't work here are some possible reasons. The flash works because a power inverter will charge a capacitor at about 350 volts. These are required to make a small lightning inside the flash tube. If the capacitor is damaged it will not charge, and the flash woun't work. If the invertor is damaged, it woun't charge the capacitor, and without those 350 volts the lightning inside the flash tube woun't go on. If the components that links the the camera's internal processor to the inverter circuitry doesn't work because of some failure to those components, again the inverter woun't work. Any shortcircuit or open circuit or imperfect contact can result in this. Even if the camera's firmware was corrupted in some way it could fail to instruct the camera to charge the flash circuitry. As you can see there are many reasons for that but only a service center can make the correct diagnostic. It isn't adviceable to dissasemble de camera yourself and tamper with the invertor circuitry as you are exposing yourself to those 350V. You may get some nasty electric shocks or damage other components. Therefore, I think the best aproach to this problem is to have it diagnosticated and fixed by a specialised service facility.
Mar 13, 2007 | HP Photosmart 735 Digital Camera
HP Photosmart 735 Digital Camera Logo
152 people viewed this question
Top HP Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
