Question about SanDisk Sansa m250 MP3 Player
HELP! my sanza m250 can't see the song files even though the songs can be played on the player
Hi, I have just had a new m250 one month ago, I copy the mp3 song files from my computer to my mp3. The songs work just fine on the player, but when I connect to the computer, there is no song files. I want to copy the song for my friends and also want to delete some songs, but there is no files when it was attached to the computer. I can't do anything. I tried to change to MSC and auto for the USB format, but it still does not show any music files. (When I change to "auto," the computer does not recognize the sanza, but when I change to MSC, the computer recognize it, but no sound files anywhere, even in the audible files, it's empty). I also tried to reformat the device, but it says that "I do not have sufficient rights to perform this operation." What should I do? Please help me!!!!
  • 3 more comments
  • Anonymous Sep 28, 2008
    I Have a similar problem. My sandisk has wma files on but I cannot see them on windows on my computer. I need to delete these to add more...I can see them on my player menu but following the delete instructions it doesn't delete them. I added some Madonna mp3s which show ok on computer and player and which I can delete from computer but not the player.
  • andyvphil Oct 13, 2008
    This problem is posted multiple times on FixYa, and I haven't seen a real soltion yet. For the second time,
    I have the same problem, and the proposed solution doesn't work. To clarify, there can be audio files on the device that are invisible to Widows Explorer and WMP (I am using XP), although they are still there when you use the player. These are visible in plaintext in the file MTABLE.SYS but if you edit it with, say, Notepad, the device rebuilds the MTABLE.SYS file with all the files you would like to delete. If you check the properties of the MUSIC folder only the visible files show up, and deleting that folder along with RECORD and AUDIBLE does no good whatsoever. Probably related is the fact that in WMP the Sync view "Sansa m250" device reports sucessful "Sync Results" but "Artist","Album","Songs", etc all declare "there are no files on this device" even when you've just synced non-invisible (deletable) files to the device. Apparently the device has a proprietary file system and is faking, unsucessfully, its responses to the applicable system calls. Or somesuch screwup.
  • satishpn Nov 03, 2008
    I have a ditto problem as metioned earlier by luizzy.
    Have a M250. I can listen to the music..but when i connect it to my XP OS  laptop..i dont see any files. Somebody please help! Have tried putting it to MSC, but does not work!
  • cindiwindi Nov 12, 2008
    Mine worked perfectly fine, I could see, add, and remove the files from the player while it was attached to my computer UNTIL I installed IE7. Now the player is being recognized as file storage only when I connect it to my computer and it shows NO FILES on it. I am so frustrated I am ready to pitch it.
  • Celtic Rose Nov 26, 2008
    I have had my mp3 plaer for about a year almost two and it's just now showing it as removable device. And I'm not able to see my other music files that I have allready on my mp3 player.
On the MP3 player, go to Settings> USB. If Autodetect is selected, select MSC (only one or the other can be selected).
Posted on Nov 12, 2008
Rock 'n' roll! I switched mine FROM MSC to the other choice (sorry, it's plugged in right now and I don't want to jinx it by unplugging it and seeing what the other choice it) and it worked!!! I just opened it in WMP and there's all my long-lost music. So I guess try both. Thanks for the help -- even if it was indirect, I would never have figured this out myself.
Posted on Jan 10, 2009
    Scholar:
  • 51 Answers
Here are few things to check with to get your device working....
1. Check the version of Windows Media Player you have. Open Windows Media Player - Go to Help and choose: About WMP and that should tell you the version. 2. Upgrade WMP to v11 from this link: http://www.microsoft.com/mediaplayer  3. If you have both and if your device is still detected as a Removable Disk, follow these instructions:
i. Connect your Device
ii. Right click on My Computer and select Manage
iii. Select Device Manager
iv. At the right hand side look out for Portable devices and click on the + symbol to display your device
v. Right Click on the device and select Update Drivers
vi. Select 'No, not at this time' and click Next
vii. Select 'Install from a list or specific location' and then click Next
viii. Select 'Don't search, I'll choose the driver to install' and then click Next
ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use.
If none of these solutions work, you may have to chek for any firmware update.
wish you good luck!!!
Raj
Posted on Jan 24, 2009
    Problem Solver:
  • 18 Answers
I want to confirm cindiwindi's solution. It seems to have to do with how the Sansa reports itself to Windows when it is attached to the USB port -- as a simple mass storage device or as a specifically media device. It's really dumb that SanDisk doesn't prominently and clearly document the problems caused by this confusing "feature".
Posted on Nov 13, 2008
Hi i have the latest sanza fuse i put 50 songs on it and can see them when it is connected to the laptop but when disconnected it only shows 10 songs how do i find the other music i have downloaded?
Are all the music files you copied onto the MP3 player are in mp3 file format?
If not the player may be displaying only the mp3 music files.
Foe instruction on converting music and CDs into mp3 music files, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Dec 09, 2010 | SanDisk Sansa e260 MP3 Player
I bought an sansa about a month ago and i dont know how to put videos on it how do i go by doing that
hi,
your sansa m259 mp3 player does not support playing video songs(.wmv).You can listen to the following supported audio files only (.wma or .mp3) in your player. If you want to listen to video songs, try finding the software which converts video files to audio files, convert them and you can listen. Google it up to find numerous software.Hope you are clear now.Please rate my solution as helpful.
Mar 09, 2010 | SanDisk Sansa m250 MP3 Player
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
I want to erase all the music that is in there and
connect it to pc their u can check songs and remove unwanted songs otherwise format the drive which appears nd copy paste new songs....
Sep 11, 2009 | SanDisk Sansa m250 MP3 Player
When playing my mp3 the songs that i have downloaded off my pc from a paid site, across the screen of the sansa says synchronize to continue your music subsription. the songs will not play please help me
Even though you should be able to resynchronize the files through Rhapsody in order to update the licenses on the music files, in my experience with this player, you have to go through a long, painful process:
1) Open Rhapsody
2) Connect your mp3 player to the computer
3) Delete the songs off the player itself using Windows Media Player - but make sure you still have a copy of these songs on your computer
4) Reload the Rhapsody songs
If your subscription to rhapsody expires, you will no longer be able to use the songs unless you buy them from the Rhapsody Mp3 Store.
-Tha Mp3 Doctor
Mar 22, 2009 | Audio Players & Recorders
Cannot Copy Music
u want to convert the song into mp3format using real player.
Sep 18, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Sandisk sansa m250 not working properly
try upgrading the firmware as follows:
Before installing the player must be in MSC (Mass Storage Class) mode to run the firmware.All files will be deleted. Backup your files.
(To switch modes, Go to Menu > Settings > USB > The two options are MSC and AUTO DETECT (MTP) : select MSC)
Installation Instructions:
1. Download and run firmware from: http://www.sandisk.com/Retail/Default.aspx?CatID=1326
2. Follow instructions in installation.
Hope that helps!
Jun 20, 2008 | SanDisk Sansa m250 MP3 Player
My sansa m250 help
click refresh on your windows media player!!
Dec 27, 2007 | SanDisk Sansa m240 MP3 Player
Digital mp3 player
the file you are trying to copy might not be an mp3 file. mp4 files, and i-tunes files will not open on an mp3 player, they only show up as data. quite simply, you need an audio converter.
Feb 23, 2007 | Coby MPC-848 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
917 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
