Question about Garden
Lawnmower Starting Pull Cord Replaement
The Starting Pull Cord on the Husqvarna Lawnmower Model 147S broke while starting it,how do I repair/replace it? (Lawn mowers do not appear in any catagory?)
  • Deborah Harcourt
    Deborah Harcourt Apr 29, 2009
    my husqvarna royal 48 has same problem. My dog chewed through the cord and now I need to replace it, looks like the top of the mower where the cord comes through is actually riveted to the machine so I can't take it off to replace the cord
  • 45 Answers
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Posted on Sep 27, 2008
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
What do i do to put new pull cord in husqvarna Lawn edger
Remove pull starter off and wind on the new cord then wind up the spring tension so it recoils.
Aug 31, 2014 | Husqvarna Garden
Husqvarna 325L x-series pull cord repair.
From my experience, the trick is to pull the cord all the way out, then attach the pull assembly to the engine, and let the pull rope win back in place. hope that helps.
Aug 28, 2012 | Cars & Trucks
I have a Toro Self Propelled lawn mower. The pull cord broke when I tried starting it. As I went to fix the cord I noticed that the spring to pull the cord broke. Is there any way to fix the spring...
You need to obtain the model number off the engine and go to a website that has small engine parts, and likely schematics. Enter the model number and find your engine and when you get a list of illustrated parts drawing select the one for the starter or recoil strarter or some such listing. This will give you an exploded view illustrated parts drawing and you need to find the broken parts. Take the number that identifies it on the drawing and look to the associated table. This will give you a part number and allow you to order it.
I hope this helps.
Jul 22, 2011 | Toro Lawn Mower With Toro Power Tools
The pull cord to crank up the weed eater is not pulling out.
You can try replacing the cord with new,failing that if the cord is sticking on starting,and releasing the cord,you will need a new starter clutch,you should check with your servicing agent first before commencing work,as sometimes these are not worth repairing,rgds
Sep 26, 2010 | Husqvarna 28cc Gas Line Trimmer
Murray 21 inch 3.75 lawnmower. Not starting.
buy a ethanol based spray called start ya bastard. spray in the carburator and then pull the cord. 9 out of ten it will start
Mar 14, 2010 | Garden
Pull cord stuck in the out position
this can be caused by sevral things inside the pull cord hub assembly. examples: Dirty inside & needs taken apart & cleaned. something logged inside, plastic spool tabs broke, spring/s broke, levers broke or any of these items could just be to worn. replacement parts should be available.
Oct 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
May 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Pull Start Locks
Disassemble and, re-engage the pull cord locking pawl spring
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,309 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
