When we start my denon avr1907 display work for only 2 seconds and after display totally turn off then after 5 hours when set turn on again same problem plz help me
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
TIME AND DATE
CHRONOGRAPH
4. Press ADJUST to view lap time. Press again to resume lap timing.
1. Switch the source OFF.
2. Enter the Time setting mode.Hold ^ button for 2 seconds
3. Select "Hour" or "Minute"
with the 2/3 buttons.
4. Set as desired time with the
5/° buttons.
As soon as you switch to "Minute", the seconds start counting from 00.
5. Cancel the Time setting mode.
Note:
? Holding down the AUDIO button for 2 seconds also cancels the Time setting mode.
? To turn the time display ON.
The time display disappears temporarily when you perform another operation, but the time
indication returns to the display after 25 seconds.
Note:
? When the sources are OFF, the Time appears on the display. Pressing the CLOCK button switches
the Time display ON/OFF.
Welcome to FixYa!
Here's your request.
TIME AND DATE
CHRONOGRAPH
Thank you for using FixYa!
Have a great day.
Jas247
Hi, 1. Switch the source OFF. 2. Enter the Time setting mode.Hold ^ button for 2 seconds 3. Select "Hour" or "Minute" with the 2/3 buttons. 4. Set as desired time with the 5/° buttons. As soon as you switch to "Minute", the seconds start counting from 00. 5. Cancel the Time setting mode. Note:
• Holding down the AUDIO button for 2 seconds also cancels the Time setting mode. • To turn the time display ON.
The time display disappears temporarily when you perform another operation, but the time indication returns to the display after 25 seconds. Note: • When the sources are OFF, the Time appears on the display. Pressing the CLOCK button switches the Time display ON/OFF. Thank You.
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
1. press the menu/set button on component to select display mode 2. use the +/- button to set the time mode (AM 12:00 blinks) 3. press the menu/set button for at least 2 seconds (the hour will start blinking) 4. Use the +/- button to set the hour, must roll the hour to change am/pm 5. press the menu/set button to switch to minutes 6. use the +/- button to set minutes 7. press the menu/set button to finish setting the time
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US) These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
