Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC W50 Camera - Trouble with Flash
Sometimes when I use my camera (not too often) the picture comes out perfect - just the right amount of light, etc. Most of the time though, the picture comes out real dark - sometimes it comes out almost whited out. I have tried every different setting possible - but, the problem still persists. I can take outdoor pictures without any problem - so, I am guessing the problem has to do with the flash. The camera is just a little over a year old and I do not feel like buying another - any help would be appreciated.
  • Anonymous Sep 25, 2008
    I'm having the same issue. It used to be that my camera would take great pictures without even messing with any of the settings. I would just leave it on auto flash and everything worked fine. But now, it seems I only get 3 kinds of pictures: they are either TOO bright with almost everything completely whited out, it's too dark (even though the flash still went off), or everything just takes on a yellowish-orange color. I've tried tweaking the iso settings and ev but it doesnt help at all and isn't the issue. No one ever uses my camera except for me so I know someone couldnt have screwed with anything and I'm just at a loss. I should mention that this problem only arises while indoors as it still takes decent pictures outside with sufficient light.
    Sergeant:
    Champion:
  • 435 Answers
Hi, I guess you are using the automatic mode ( not the "P" mode).
You should enable flash only when there is insuffient light. If you use flash in broad day light, your pic will be whited out. If you dont use flash in dark or low light, your pic will be dark or very dark.
So, when it comes of dark, try enabling the flash. If its still dark, increase the flash compensation (the eV value). If its still dark, increase the ISO number.
Hope these help.
cheers,
Posted on Sep 20, 2008
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01
I've had my dsc w50 for about 2.5yrs and its just started the same milarky! Go to menu, set up 1 and re-initialise, it cleared for me then came back again. Went through the same process just now and error has gone for time being, although I think the flash is on its way to heaven. Some pictures are dark and others completely white out!!
Taking it in to the sony shop tomorrow to see if they can lend any advice - I hope it doesn't mean a new camera as I've not over used it....
Let me know how you get on
Dec 03, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01 flashing
i also have E:91:01 flashing on my camera and when i take a picture it does not flash even when my camera is on flash
Aug 24, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash does not turn on
A camera malfunction has occurred. Reset the camera, then turn the power on again.
Reset button is under battery lid.
Feb 13, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash on Cyber-shot DSC-W50 not working properly
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Dec 27, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Flash is inconsistent
I have the same issue. One picture the flash is perfect the next there seems to be a "half" powered flash and the pic is dark
Dec 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Flash
Did you try to reinitialize? Setup menu go down to the third Setup#1 menu and make sure you click OK to reinitialize. That's what the manual said.
Apr 28, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Orangr light
Seems like you have the AF Illuminator set to on in the SET UP. This lights up every time the camera thinks it is not light enough, gives more brightness to the picture!
Mar 30, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Flash problem
The CCD element has been a great problem in this camera along with a faulty iris in the lens. I would return the camera to the Sony facility in Laredo, TX and let them know the exact symptom you are having. I see many of these cameras being repaired as a "courtesy" because of the widespread problem. Good Luck to you! Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
106 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
