Haier Plasma 42hp25bat remote codes
The codes for Haier (10034 & 10768) won't work on my Comcast Remote. Any other suggestions?
4 Suggested Answers
SOURCE: Haier HD tv purchased
Problem has not be resolved, but after reading your response I understand that you are offering me help but at a cost., I find that unbelievable because I just purchased this TV haven't had it 2 weeks., and you can't even tell me if there any more codes to try and make my digital cable service remote work. If this is what you are telling me, then I will surely add my comments to your web site. Thanks for standing behind your product.
Posted on Dec 31, 2008
h_caines
  • 8 Answers
SOURCE: Comcast Remote Control Code
10150 worked for my mitsubishi wd65737
Posted on Jun 17, 2009
SOURCE: Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
Posted on Aug 20, 2009
budmrtn
  • 11361 Answers
SOURCE: Need comcast remote code for Haier LCD 22
You can download the user manual for your remote here: http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Dec 07, 2009
Tv does not respond to the remote
Check the remote control first, for its infrared emission. If it found OK, check and replace the infrared sensor inside the TV.
Aug 29, 2012 | Haier HP50B 50 in. Plasma Television
Need remote control codes for Haier L32B1120 ,for comcast remote
Hello
Setup codes for Haier TV with Comcast -11412 universal remote control are:
11034, 10768, 11009
OK
Aug 02, 2011 | Televison & Video
Haier HL32R1 tv code
This is the only Comcast remote that i can find, I hope it is the "all in one remote".
Copy and paste this into your browser:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=comcast&dv=universalremote&md=custom3device&kw=comcast+remote&st=&ar=&dt=&so=&pg=3&file=others/comcast/custom3-manual.zip
Cheers!
Feb 25, 2010 | Televison & Video
I have a haier tv with a comcast remote. Need the Haier code for the comcast remote
10768
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
May 28, 2009 | Haier HL42E LCD TV
Nothing works
i had exactly the same problem but not anymore. i called the haier co. and they told me to order a new remote control so i did. i got my new remote and i turned my tv on and pushed the tv/use and it worked thank god. so maybe you could try it. remote control only 20.00 good luck!
Mar 14, 2009 | Haier HP42BB 42 in. Plasma TV
Dec 30, 2008 | Televison & Video
I can't get my Comcast remote to work with my Runco PL42c Plasma TV
Call Comcast they will talk you through it all the wayyyy.
Feb 11, 2008 | Televison & Video
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
