Retro-fitting with a thermostat
What is the best way to retro-fit my unit with a thermostat?  Product suggestions, Financial practicality, labor-intensity-->  all info would be greatly appreciated!
    Scholar:
  • 121 Answers
If you have a wall or window unit you'll have replace the t-stat by the model number. If you have a central system you get a t-stat from a hardware store from $30 to $200 depending on model. I would recommend a digital t-stat because they are accurate +/- 1 degree where a mercury t-stat is +/- 10 degrees. either way they come with instructions and only take a few minutes to install.
Posted on Sep 27, 2008
More on the hydraulic,problem case ih 7250 break away remotes ******* blocked with plastic .Ray
best guess plastic internals
look like a throw away
big problem
cant find any new for sale ....used ones rare
may have to retro fit nearest fit
Nov 02, 2016 | Cars & Trucks
How much freon goes in a 1991 honda civic?
Your Honda takes R12 freon, R12 freon is no longer sold, if your car has not been retro fitted to 134a freon, you will have to buy a retro fit kit, so you can install 134a freon, If it has been or after retro fitted, total freon 1.5 lbs 134a freon.
Jul 09, 2010 | 1991 Honda Civic
I bought the retro fit kit and the low side nozzle doesn't fit and autozone told me ford needs a special nozzle for the retro fit is that true?
No it not true, maybe they just don't have it, I know Napa auto parts stock this there part, the number is #409996 and it is a stocking item run's about $30.00, take that part back to autozone and go over to Napa.
Jun 30, 2010 | 1990 Ford Bronco
I have a 1993 Chevrolet c-1500 truck with A/C. It is not blowing cold. I noticed that the sticker on the compressor says R-12. What can I put in that is safe?
You Must Change over to 134-A and this Requires Replacment of All Internal Rubber "O" Rings
Although I Have Purchased the ADAPTER Fitting and Just Filled My Personal Vehicles With 134-a With No Problem
Jun 14, 2010 | 1993 Chevrolet C1500
I have an old sony rmx20 discjockey. It has
1. you may not be able to go through the auxillary to get sound from this unit main because, from the inference here is that it is mono input.
But not being able to see the unit I am not privy to the full scope of the functionality of it.
Retro fitting new device with old usually means that modifiction is needed to make the new device couple or patch to the old device.
This may mean that the unit (old) will need to be disassembled and the main board scanned for a component to be insert or wired to accomodate the new device for audio to be heard trough it,.
There is a site called "instructables" that will assist in retro fitting new audio device to new but to give step by step here in this forum would not be accomodating to you because of limitations that is the unit being physically look at to assess the proper way to complete this project.
I hope this helps.
Feb 07, 2010 | Sony Car Audio & Video
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Nov 09, 2009 | Empire Hight Efficient Direct Vent Wall...
Can you retro fit a Calypso pump with a lint filter to stop it from getting clogged?
Hi
Very inventive and imaginative.
It is best that your lint filter gets glogged and you regularly clean it, rather than letting the link work its way down to the water pump and clogging that.
To retro fit a pump to disperse the lint, seems like a big engineering task, and you'll find after all the effort, the lint would need to end up somewhere else and still need to be cleaned.
But not to dismiss your idea, if you find an effective solution, you may even patent it.
All the best.
Ash
Oct 29, 2009 | Kenmore Washing Machines
Intherterm retro fit kit
Intertherm lists dealers here: http://www.intertherm.net/
Depending on how old you may be out of luck.
Apr 26, 2009 | Procom (177653) Utility Heater
Retro-fit drain hose
hi not seen one of these retro types but having always wiped the seal and door after use as recommended with clean damp cloth prevents seal deteriation i would have thought this drain?on retro type that drains accumulation of any water from seal would be draining inside the outer drum and thro to drain into pump? seems odd?
Oct 22, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
