New Whirlpool Duet Washer(WFW9300VU02) F28 error
I am a contractor who has installed a new Whirlpool duet for a customer. When trying to run a test cycle, water will fill drum for about 5 seconds, then stop when a F28 error appears in display. This happens on all load selections (delicate, normal, heavy etc) I have tried it with clothes in washer and empty. Same result.. Any ideas?
Jim in S.C.
  • Anonymous Mar 28, 2014
    washer starts to fill then stops and doesn't do anything then f28 fault code shows up
  • 725 Answers
You can call whirlpool for service but the tech sheet f28 has a communication problem from you computer to the motor..
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
Check connections of the CCU board within the housing.
Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Posted on Sep 21, 2008
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Duet sport wfw8300sw03
try unplugging and plugging back in. a reboot of sorts.
i am not a repair man, but I own one too. good luck.
Jan 28, 2018 | Whirlpool WFW8300SW
F28 code on whirlpool duet washer. The door locks
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
You can download the online repair manual in the below link
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
On page# 4-20 it shows how to access your MCU.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport will not work
Mar 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
1,494 people viewed this question
Top Washing Machines Experts
