Question about Electronics - Others
Recovery of data from flash usb drive
I have purchased a kingston 32GB usb. I tried it by copying some data on it and then I tried to format it but it show no system to format when I use format command on it. But data can be deleted. I took some files on it in simple and RAR format but when I again tried to paste the data it shows following message and can't open the files on it but shows space ocupied by data on it through property.
"Please insert the last disk of the Multi-volume set and click Ok to continue"
how can I find my locked data I cant understand. pls help me.
S.D.Sharma
  • Palmbeach
    Palmbeach May 11, 2010
    This message
    means you have put something on the drive which is incomplete. When the drive is read by your computer, it delivers a checksum error because of a missing or incomplete file that is associated with something that you have put on the drive. You do not need to format the drive and you certainly would not want to do that if you have data on it because formatting will erase all your files!. Simply press ok several times and the insert last disk message will disappear.Then remove the files one by one by deleting them until the error no longer shows. You can then put each file back on the drive.
    Why does this happen?
    Sometimes, if you have a power glitch when transferring files they can be corrupted especially if your computer is slow and you transfer a lot of files at the same time. It is best to transfer just a few files at a time.
    Just remember that the error you are getting is nothing to do with your flash drive or the new data you are trying to paste or transfer. It is simply due to something that you tried to paste earlier. Never format any drive that has data on it unless you are happy to lose all the data and wipe the drive clean. Also, do not interrupt data as it is transferring to a flash drive. If you decide you want to cancel the transfer, wait until it has finished and then just delete it. Try not to stop it half way through.
  • Anonymous Mar 21, 2014
    I have a 16gb usb thumb drive that is only showing up as 1gb how do I set it back to default settings formatting does not work
  • 75 Answers
Try formating it with other computer...
Posted on Sep 23, 2008
Can't format kingston datatraveler G3 *GB
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jun 20, 2012 | Kingston DTIG3/32GB 32GB DataTraveler G3...
32Gb kingston pendrive not working. Any data copied get corrupted
When i copy any data to my 32 Gb Kingston pen drive whether any audio or video file or any software, the data get corrupted or may be deleted. some trimes it happen that some of the AV files are working. Why this happened that the data are deleted. I have lost many of my files due to this.It cannot be fomatted also. Please sort my this problem. Thanx
Jun 27, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Not able to format 32gb kingston usb device givin
this problem may be due to a strong virus
just go through Dos promt
by writing cmd in run place at start menu
and then cd..
till u not get c:\ prompt
then write pendrive location like g: and press enter button
then u get g:\ then write format and press enter
hope by this process u will format ur pendrive
Mar 02, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Once transferred the data to the USB, it shows its correpted.
I recommend that you re-format the drive/device in the system you intend to use it in most.
If you format in the NT mode then your Windows 98 etc will not be able to read the data... this MAY be your problem?
If you are using NT see if it gives you the option to format in 32 bit mode? You MAY be able to use it with both operating systems then.
Hope this helps!
Feb 20, 2009 | Kingston Technologies 512MB DataTraveler I...
Kingstone 32GB Pendrive problem
this must a result of virus, check your pen drive witha updated virus cleaner and also protect your system with a lattest virus gaurd.
Jan 15, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Files corrupted
Hi vaibhavmore8,
You should try formatting the device to see if that clears up the problem. If the format fails to run then the device is bad and needs to be replaced by the reseller or Kingston. If the format completes but doesn't help the problem then the problem is with the files you are copying not the USB drive.
Formatting a USB drive. It will delete all data. Right click on the drive letter and select format from the menu. Click on Start.
Kingston Tech Support
Jan 05, 2009 | Kingston Technologies 512MB DataTraveler I...
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
Electronics - Others Logo
385 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
