Question about Samsung AH5900092W Remote Control
Configuring Sky remote
How do I configure my Sky remote to work fully (volume doesn't- channel change does), with my Samsung 37 inch LCD?
  • Anonymous Mar 17, 2014
    how can i tue my samsung remote to work my sky box
  • 27 Answers
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
    New Friend:
    Problem Solver:
  • 10 Answers
0060 does not work with my model of Samsung
I found the code can vary according to the particular Sky Remote you have.
Look in the battery compartment for the version (it will say something like Rev 8R or Rev 9F)
For my model I found code 1647 worked with a Rev 9 remote but not with a Rev 8 remote
I found codes 1277, 1340 and 0646 worked with a Rev 8 remote but not with a Rev 9 remote
Other codes that worked with certain older models of remotes included 2079, 1177 and 0088
Posted on May 17, 2013
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
What is the code for sky?
You can either use the "Service" button and follow the onscreen guide for "program your remote"
Or
On your Sky Remote, away from your TV and Sky box (not pointing at either):
Press TV
Press SELECT then the RED button together for a couple of seconds.
You will see the light flash twice at the end of the remote
Press 0 6 4 6 SELECT
Your Remote should now work the TV Volume, Channels etc.
The HELP button switches the TV Source.
Sep 06, 2009 | Samsung LE26R71B 26 in. HDTV-Ready LCD...
Need to get volume on the sky remote to work,need a code
You need to bring up your sky help section which is all in the skybox look for menu or help and there is a list of all tv`s in there it will tell you also how to fix your remote, you will need to look for the model tv you have, you can also search online with your tv model and get it that way, which ever is easiest.
I hope that helps?
May 01, 2009 | Televison & Video
Sky remote code
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Apr 26, 2009 | LG 37LG30 37 in. LCD HDTV
Remote to opperate sky volume
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Apr 17, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
My sky remote only works part of tv
TV
RED + SELECT
TV
0056
Right you said in your post that it only works part of the tv, what this is when you have saved the code into the remote it is very close but not the correct code for the LG Model you have. So imput the code as mentioned above but when your checking the volume dont press SELECT straight away try the help button. power button etc then save that code if it works them. when it is the correct code you should be able to press the TV button then power = power . Help = changes av / source. Number button change channels etc. On certain tv's on a sky + or hd the pause/play changes the aspect ration on the tv aswell. When this sorts you out please leave a thumbs up cheers
Little Dish Fitter
Mar 20, 2009 | LG 37LG30 37 in. LCD HDTV
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Samsung AH5900092W Remote Control Logo
739 people viewed this question
Henry  Thomas
Henry Thomas
