Question about Sewing Machines
New Home L-373 Sewing Machine
The brand of the machine is a NEW HOME MODEL L-373
I need to know how to re-assemble the needle shaft components
  • 1 more comment
  • lknou Sep 20, 2008
    I need to know how to re-assemble the parts on the needle shaft of my New Home L-373 sewing machine.
    This machine is about 15 years old. The manual simply is titled "Instruction Book" "Model L-372/L-373." This is a user manual, and only has the info I gave in American and French.
  • Ronald Mueller
    Ronald Mueller May 11, 2010
    i need as much info as possible what is the model number this will also include a name as well like for example New Home Precision plus L-373 how old is the machine
    President:
  • 1,263 Answers
You can find a replacement manual at this sit www.sew4less.com this should help you with the right diagram for your machine please rate this solution....thanks
Posted on Sep 20, 2008
  • Ronald Mueller
    Ronald Mueller Sep 20, 2008
    what the heck was that rating for i gave you a place where you can get the manual for your machine you asked for my help and now this. you lost your manual for a machine 15 years old and this site has it so you can fix it and you rate the solution incorrectly. absolutely ridiculous
What kind neddle do i need for a New Home sewing machine Model HF 106
Janome sewing machine needles should work on your machine
http://www.sewingpartsonline.com/janome-hf106-sewing-machine-parts.aspx
or
just try good quality brand needles with this code: 130/705H
Jul 03, 2017 | New Home Sewing Machines
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
Why won't my new home super stretch stitch model-844 pick up bobbin thread to sew manual book
If you need a manual, search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer.
Try installing a brand new needle. A bent needle sometimes will not connect properly. Be sure that both upper and bobbin threads are threaded correctly.
On the other hand, the needle/hook could be out of time. You can check that by hand turning the handwheel and watching the needle/hook movement. There are a multitude of web sites and videos that discuss timing. Or--check with a sewing machine technician.
Mar 20, 2016 | New Home Sewing Machines
Thread jamming in bobbin mechanism, breaking upper thread and jamming bobbin.
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
May 04, 2012 | New Home Sewing Machines
My daughter in law's machine won't pick up the bobbin thread. I've never even seen a bobbin that loads like that so I don't know what to tell her. In fact, I've never even heard of a new home sewing...
New Home is Janome.
The bobbin thread may not be picking up because the needle is in backwards.
Refer to the manual for the machine - some require the flat side of the needle face to the back of the machine and some to the left side of the machine.
May 07, 2010 | New Home L-373 Mechanical Sewing Machine
My New Home sewing machine is frozen.
Remove the throat/needle plate and see if thread has wrapped around the mechanics...clean the area to remove lint accumulation.
If the machine is still bound-up, it will need to go in for repairs.
Feb 20, 2010 | New Home L-373 Mechanical Sewing Machine
Need a rubber wheel for a 1946 New Home.
I have these in stock. Stepping Stones Quilts - 912-638-7128
Jul 21, 2009 | New Home L-373 Mechanical Sewing Machine
Sewing Machines Logo
231 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
