Question about Compaq Presario 5000 PC Desktop
Compaq s4300nx power supply and memory problem
I was brought a compaq that would not boot up with a long beep, one after the other. the computer is 7 years old.
  • Francisco Cortes
    Francisco Cortes Sep 20, 2008
    I cleaned up the computer taking care of ESD and put everything back together.
    the computer now won't turn on
    I solved it by doing the following:
    1. I noticed the back of the power supply was flashing so I followed the troubleshoot suggestions from compaq when the back light of the power supply flashes..
    2. It came down to it was either the mobo, memory, or cpu.
    3. I switched the memory (2 sticks of 256mb ddr) in different combinations but nothing worked, after changing and testing one combination at a time.
    4 I had ruled out the powersuppy as being the cause but I decided to still test the system with a spare powersupply and as I did a continue switching memory (one combination at a time)... the computer boot after using only one of the memory sticks...
    Not only the powersupply was faulty (despite what the compaq website indicated.. but also one of the memory sticks.... I got a little help from a fellow technitian (who deserves the credit.. I got to say). and I saved myself from repurchasing another mobo and cpu as those were the ones I thought where the real problem was.
    lesson learned: still swap for known good items while checking the obvious.
    thought I should share this!
  • 75 Answers
Try replacing the RAM....
Posted on Sep 20, 2008
Compaq gc668aar will not startup_startup repair will not fix
It isn't a Processor problem
(Or is there a series of beeps, and the fan is running wide open?)
[ Just curious. Call it a poll, if you will.....
Did you follow Anti-Static Precautions, and did you Thoroughly clean the Processor, and bottom the Heatsink; plus correctly apply, fresh new Thermal Paste? Reply in a Comment ]
Where did you get the Start-Up repair from?
What does the router have to do with this?
Do you get any BIOS Beep Codes?
You have another 'Compaq processor'.
Do you have another KNOWN to be good, Compatible Power Supply also?
Post back in a Comment
(Computer turns on does not = Boot.
When the computer boots it means Windows is running.
Power Supply turns on is also mistaken for computer turns on.
No it didn't. The Power Supply turned on, is all, )
Dec 17, 2012 | Compaq Computers & Internet
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
Computer will not start
It all depends how many beeps there were.
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
Could be one of two things: either the power supply is going bad or the RAM is either going bad or isn't seated properly inside.
First thing I would try would be to re-seat all the memory chips inside the computer. There could be up to 4 sticks of memory in some computers. If this doesn't work, try pulling the memory out of the computer one stick and a time and booting the PC. If it boots, you've found your bad memory stick. Put all the others back in and replace the faulty one.
If none of this works, you might consider calling HP (maker for compaq) for support on getting the power supply replaced.
Jan 19, 2010 | HP Compaq Presario SR1420nx...
When i press the on switch the computer light turn red color and have a beep sound.
1 or 2 beeps is normal when turning on, for most mobo's. Check the motherboard owners manual for beep errors, for example 3 beeps might be a graphics card error, 4 keyboard error, or CPU or memory. it's in the manual for the specific motherboard. You can get it from the manufacturer's website. I can not supply a link to get you the online manual because you didn't specify what kind of motherboard you are using. Does it still boot? Do you see the BIOS on screen? Any error messages? When you press the power button your computer normally should beep once or twice and then performs a POST... Power-On-Self-Test. and this is when you get any error beeps. It could be something simple like forgot to hook up the monitor, to CPU or memory is loose, or memory is not compatible if you upgraded the memory.
Oct 20, 2009 | HP (350030-001) for Compaq dc7100...
remove ram memory - it should beep when you switch it on - if no beep then check CPU in socket and cpu fan spinning when on.
Jul 31, 2008 | HP Compaq d530 SFF PC Desktop
Compaq Presaio S4200NX displays Compaq Splash Screen then a single continuous beep with but nothing else.
Most Compaq desktop that exhibits 1 long never ending beep indicates Memory error; Bad RAM. Corrective measure therefore would be replace and test.
You can try removing the memory and cleaning the gold pins with a pencil eraser and try again. If this doesn't work, guess you're back to replacing.
Good luck and kind regards.
Nov 04, 2007 | Compaq Presario S4200NX (DF215AR#ABA) PC...
Hp compaq d220 mt tower
what kind of beeps??
long beeps point to faulty memory.
one long two or three short beeps point to faulty videocard.
the devices might just have come lose......
please describe the beeps
Oct 16, 2007 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
