Question about Toshiba Satellite P35-S611 Notebook
Did you fix your laptopproblem? I'm having the same problem
I am having the same problem, the ac adapter will not power my laptop nor charge the battery while the laptop is on, when i turned it off the power led is on, if I remove the ac adapter and re-instert it charges the battery, but when trying to turn on the computer it goes back to battery power and will not use the ac adapter nor will it charge the battery,
I got that you had the same problemback in 2007 ..did you solve it? please help, i do all my work on this laptop.
Thanks
Nadia
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
Tip
Troubleshooting Laptop Power Failures - The Battery
Symptom:
Battery does not charge while the laptop is plugged.
Diagnosis & Solution:
First thing is to make sure that there is AC power to the adapter. Some AC adapters have an indicator LED which glows when they are receiveing power from wall outlets. If your AC adapter does not have one, then make sure that the cord from the wall outlet to the AC adapter is firmly plugged into the AC adapter. Also make sure that the AC adapter is plugged into an operational wall outlet. You could also check the laptop's power indicator LED to verify whether it is receiving AC power from the wall outlet or not.
Next thing is to make sure that the AC adapter's connector tip is fully plugged into the power receptacle in the laptop. If this did not help, then the next step is to check & confirm that the AC adapter itself or the cable connecting it to the laptop has not failed. You can easily verify this by using a digital multimeter set to measure DC voltage. Use the digital multimeter's probes to measure the output voltage from the connector at the end of the adapter's cord to the laptop. Compare the reading you get to the nominal DC voltage required by the laptop, which you could find written on a label stick to the bottom of the laptop. The output DC voltage from the AC adapter should not read significantly less than the nominal DC voltage required by the laptop. If you find no or a significantly low output DC voltage from the AC adapter, then you will have to replace this AC adapter with a new one.
It is also necessary to make sure your AC adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the AC adapter. Voltages should be the same, or the AC adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the AC adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the AC adapter will be providing insufficient amperes to charge the battery. Of course, the AC adapter's nominal amperage might be OK, but it degraded on usage. You can verify this by using a good or new AC adapter, or by testing your laptop's AC adapter with another laptop.
If the previous tests confirmed that everything is OK so far but your laptop's battery is still not charging when the laptop is plugged, then there might be a possibility that the battery is not making good contact with the laptop's charging circuitry. To eliminate this possibility as a root cause of the battery not charging, turn off and unplug the laptop, take the battery off the laptop, and using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self. When done, put the battery back into the laptop, plug it, and turn it on. Check if the battery starts charging or not.
What if after all this the battery is still not charging? Well, we might then start to suspect that the battery itself is bad. This could be verified either by testing the battery in a similar laptop, or by swapping the battery with a new one or one which is known to be in a good working condition. If your battery does not charge when tested in the other laptop, then it is obvious that the battery is bad and has to be replaced. However, if your battery starts charging in the other laptop, then we are left with a couple possibilities: your laptop needs a BIOS update, or your laptop's charging circuitry is defective.
When laptop owners call tech support to report that their battery isn't charging or the life doesn't seem to be what it should, tech support will often tell them to download the latest BIOS. While it's marginally possible that the laptop shipped with a BIOS that has been improved in regards to battery management, the BIOS upgrade process, called flashing, is not reversible without special equipment. In other words, if something goes wrong, instead of having a laptop with a battery charging problem you'll have a collection of perfectly good laptop parts that won't do anything. Flashing the BIOS is a last resort we only recommend if you find references on the Internet that it fixed an identical charging problem for somebody else with your exact model.
If at last it turns out to be a defective charging circuitry, then you will definitely need to disassemble your laptop in order to gain access to its motherboard. The motherboard should then be checked for any burnt out components in the area surrounding the power receptacle. Burnt out components will need to be replaced, or if not possible, the motherboard will have to be replaced.
Please Vote for this Tip if you found it helpful.
M. Omran
on Oct 15, 2010 | Computers & Internet
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 23, 2011 | Dell Inspiron 2200 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
My laptop battery i guess hit critical stage but now the system wont work with ac power
Jan 26, 2011 | Acer Aspire 7520-5185 Laptop
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Toshiba satellite m35
Are you sure that you fixed the power issue it sounds like there is still a bad connection in the power socket if you want info on this problem go to this site http://www.ask.com/bar?q=laptop+repair&page=1&qsrc=0&ab=1&u=http%3A%2F%2Fwww.laptoprepair101.com%2Flaptop%2F2006%2F01%2F04%2Ftoshiba-laptop-overheating%2F
Mar 29, 2009 | Toshiba Satellite M35-S456 Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Toshiba Satellite P35-S611 Notebook Logo
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
