Question about Lands Phones
Binatone veva 1200 cordless phone, UNREGISTER appearing on screen and phone not workindf. Does not seem to be able to register with base.
  • 2 more comments
  • Anonymous Nov 18, 2008
    binatone veva 1200 cordless phone, UNREGISTER appearing on screen and phone not workindf. Does not seem to be able to register with base.
  • nikawas Mar 22, 2009
    hallo i have twin binatone phon and one its not work probably i have this some problem with you. ith write underregister
  • andreia_a Apr 04, 2009
    I have the binatone 1200 phone and i dont know wa happened now it says unregister and its not working i cant even make phone calls.
  • Anonymous May 16, 2009
    same as above- and same product
Hi ihave phone binatone veva the phone is not working please can you help me its writing on the screen unregister thanks
Posted on Nov 23, 2008
nkrcs
  • 94 Answers
SOURCE: binatone fusion 2210 - manual
you can download the manual from here as the Binatone website does not seem to hold user manuals http://www.exteradirect.co.uk/download/product/001310/Fusion2200__Fusion2210_UK.pdf
Posted on Jul 27, 2010
SOURCE: Registering a new phone
I just purchase that same model and I had the same issue as you where the phone on the main station worked and the other 2 sitting on their own base station didn't work. What I did to fix the problem was to put each handsets (one at the time ;-) ) on the main base (the one with the answering machine). The Charge/In use light flashed a couple of time then the handset showed as Ready. I then put each handset on their individual base station and they all work fine now.
good luck
Martine
Posted on Nov 14, 2007
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
SOURCE: Binatone Veva 1210 BS Search Problem
You need to re-register the handset to the base. Look for handset registration in the user guide
Posted on Jul 16, 2008
SOURCE: BINATONE CORDLESS PHONE MA 760
http://bigtip.name/xxx/crazy/manual/manual/b_ma760_eng.pdf
Posted on Oct 18, 2008
I have a binatone veva 1200...
What does the bottom button on the right-hand row (below the "#" button) say? That should be the intercom button.
Jan 17, 2013 | Binatone Lands Phones
My binatone triple digial cordless phone keeps saying out of range and beeping every few minutes any ideas it driving me mad
It needs to be re-registered to the base, if I knew which Binatone phone you had I could have advised. Either comment to supply the model name or call 0845 345 9677 (Binatone Helpline).
Dec 10, 2010 | Uniden EXAI 7980 Cordless Phone
How do i initialise factory settings on a binatone veva 1200 i do not have a instruction manuel
There is no user guide for the 1200 but there is one for the 1210 model, the software should almost be identical, try looking at the 1210 user manual on how to factory restore it and it should be the same, all else fails call them up here is the manual for the 1210: http://www.binatonetelecom.com/products/digital-cordless-phones/veva-1210
Sep 02, 2010 | Lands Phones
I have a phillips CD240 cordless phone, on the screen is flashing SEARCHING and wont make or receive calls.
Hi, I solved this issue this morning. "Searching" means the handset cannot find the signal from its base, and if you check your base, it's more likely than not, dead. In my case, I checked this by pressing any button on the base, i.e. answer phone etc., there was no response (although the handset seems to recharge power fine for some reason).
Therefore, I went and bought a new cheap GAP compatible (binatone 1800 Single at Comet - 14.99). I then set up the base, put it in the registration mode as per the binatone instruction. Then on the Phillips CD245 handset and gone through the above registration procedure... and Voila! It worked.
Now I have a brand new base that came with 1 new handset of its own, and 3 additional CD245 handsets which are all registered with this base. So far, the sound quality is good (no different from the previous genuine set) and they retained all the telephone numbers registered with the handset.
I don't have any high regards to binatone specifically as a brand because our last corded phone system was rubbish and died shortly after 12 months guarantee but to me it looks as if GAP compatible cordless phones have certain life-span however cheap or expensive they are (while handset seem to last much longer). Threrefore, there is more incentive to buy a cheap base new (of any make that are GAP Compatible) then connect your old handset to this base and live on 12 months manufacturer's guarantee and hopefully more. On the web, I saw some comments that are saying GAP Compatible phones and base sometimes do not successfully register each other (despite even being of the same make or brand). Obviously the users make such attempt at her/his own risk but I can confirm that the above combination worked for me.
Just for info, to do the registration successfully, the both base and handset must be in "Registering" mode. First, to get the base in the registration mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep). You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting".
I hope this is helpful.
Best,
Ken
The above, however, works only if the Base is still functioning.
Jan 02, 2010 | Philips DECT5112 Cordless Phone
Fault with Binatone Veva 1210 answer machine
Ask here, they have already found a lot of Binatone manuals. Send them a request.
Oct 17, 2008 | Uniden EXAI 7980 Cordless Phone
how do i register my new samsung rant phone ?
Oct 04, 2008 | Uniden DCT648-3 Cordless Phone
I have a Binatone Veva 1210 and I do not get to hear as the volume is very low and do not know how to make the volume loud. Can anybody assist
Jun 24, 2008 | Uniden EXAI 7980 Cordless Phone
Lands Phones Logo
802 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
