Question about Rancilio Silvia Espresso Machine
Weak coffee I've just bought a silvia, and i followed all the instructions for startup, but i'm getting really weak coffee. What should i check/do?
The simple fact with any espresso making is that to get good coffee you MUST:
  1. Grind your own freshly ground beans - grind matters alot. With a good grinder (a burr grinder, not a spice mill). This probably makes the most difference.
  2. Pack the coffee properly using a solid heavy tamper (not the flimsy things you get with the machines)
  3. Buy good coffee - shop coffee is old and stale. If you have to buy shop coffee get something like Illy - its much better than the others.
  4. Ensure the machine is hot, and also that the portafilter is hot (leave it in there when not in use). Cold machine == sour coffee
  5. Dose the coffee properly.
  6. Adjust the above until the time taken to pull a shot is approx 23 seconds - you may need to 'sacrifice' some coffee to get to this point.
  7. And in my opinion only use a double basket - single baskets are hard to use, don't pack well are weak, and inconsistent. A double basket uses more coffee but you get a way better result, more often.
Sounds like a lot of work, but the difference is huge. I used to use pre-ground coffee from a shop and it was prety bad. As soon as i took it more seriously and invested in the right gear and the right coffee - well i can make coffee at home that is significantly bettter than anything i get in coffee shops and restaraunts.
Posted on Nov 08, 2008
Our Silvia, almost 8 years old, is putting out shots too fast (10 to 15 seconds), even though we've been dialing down the grind on Rocky more fine, putting more coffee in, and tamping harder. We...
Try to redo what you have been doing, but set it to the extremes to see if everything is functioning. If you set the grind say to 4, it should come out very slow or maybe not at all.
Jul 11, 2011 | Rancilio Silvia Espresso Machine
Hi, I just got my new rancilio yesterday and used it for the first time this morning but the coffee does not seem as hot as what I get at a coffee house or even from my former stove-top pot? I am following...
No the temperature is fixed. If you make the coffee just after is heated up 10-20 minutes then try to lush some water from filter holder first in the cup you will serve the coffee. Flush for some half a minute and the make the coffee.
Nov 01, 2010 | Rancilio Silvia Espresso Machine
I bought a used machine. I am not getting really strong, good espresso. How can I do some service checks?
Many factors are involved here. Start with checking your grind, tamp, freshness and quality of the coffee, degree of roast.
www.kaldi.com
Oct 11, 2010 | Rancilio Silvia Espresso Machine
My Rancilio Silvia leaks water from the pump where the exit tube is mounted. Shouldn't there be hose clamp or similar to ensure water tightness? What can I do?
Not really since it is not pressurized, check the hose there might be a small crack, or you can use a zip tie as a clamp.
Apr 15, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Unit fails to prime> have followed instructions. Is there a reset button?
Hi
You might want to check you hoses that connect to the pump and make sure that both of them are in the water tank. They will come loose from the pump and the pump won't prime.
Nov 28, 2009 | Rancilio Silvia Espresso Machine
Silvia pressure issue
The Silvia comes equipped with a "pressurestat" that may have gone out of adjustment. Do a google search on that and you will find numerous pictoral guides on how to do this. The owner's manual that came with the machine (they have electronic versions at espressotec.com, among other places) will also give you basic instructions. Good luck!
Aug 22, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso water flows too quickly about 7 seconds
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Feb 09, 2009 | Rancilio Silvia Espresso Machine
CREME
Hi ensure that the group head has heated up before using I tend to screw the head in and place the porta filter on top of the machine to allow it to heat up (heat the machine up for at least and with regards to the tamping ensure that you tamp firmly and twist at the end to smooth the surface.You could try tampind the cofee in the portafilter before placing it in the group head then after you have placed the porta filter back in give it another quick tamp remembering to twist at the end to help smooth the surface.
Then pull a shot. I get great crema like this.Also ensure the cups are warm.
You can heat the brew head and cups by running hot water through them before using as well this method is called cheating the Silvia
have a look at this http://youtube.com/watch?v=5mapl0Fw-_M&feature=related
Hope this helps
May 04, 2008 | Rancilio Silvia Espresso Machine
Steam blowing out of group head
Were you using cleancaf to descale? If so, it is not a strong enough descaler. Use Dezcal. or a Dezcal cleancaf mixture. The two work great together.
Make sure you get some descaler in the solenoid area by turning on and off the coffee button.
Hope it works out for you.
Espresso Parts and Cleaning Supplies
www.CeriniCoffee.com
Nov 12, 2007 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
171 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
