Question about Denon AVR-1905 Receiver
When i power on the device, it comes on but goes off about 5 seconds later.
The device does power on, but when I push the switch to turn it on the display lights up and it stays on for about 5 seconds and then goes off. The on/standby button then just blinks. This unit is only 3 years on and I don't want to have to replace it if necessary. Does anyone know about this problem? If so, is it expensive to fix? Thanks for any help you can give. Ron I have the exact same problme as listed above. The receiver light comes on for 5 seconds and then blinks red and shuts down. I do not see any solutions for htis posted.
Dan
  • 1 more comment
  • bruces6827 Dec 11, 2008
    same problem plus it appears zone 2 is locked on and it is locked totally into analog. obviously if we can not get past the blinking power light and shut down then the rest means nothing ! I think we all have a pc of S--- and should considr a different brand , How about you guys ??
    bruces6827@comcast.net
  • lil_dee_1991
    lil_dee_1991 Apr 21, 2013
    i have a onkio htc r390
  • lil_dee_1991
    it has the same problem i did find this post that i am reserrching i think this may work The unit most likely blew up a capacitor. If you look in through the slots on the top of the unit you should see 2 big black caps (C6901 and C6902) with shiny silver-ish tops. I should also point out that you probably flew up a 125v 8A (F901) glass fuse on the board that the AC cord plugs into. The glass fuse can be found at Radio Shack, but the caps are a bit more troublesome to find. They are 10,000uF 69v and thats just not a standard part, so you may need to up the voltage requirement and buy a 75v cap. Total to fix the amp yourself:
    Genius:
  • 1,175 Answers
Hi...
1st thing to check is for GOOD speaker connections at both ends
and not mixing A and B speaker wiring.
A Denon is usually a good brand. Might be worth servicing if need be.
Posted on Apr 11, 2009
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
Tip
Chevrolet service light 1991-01
Camaro
1998-01
To reset the "OIL CHANGE" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and then goes out, the system is reset.
Corvette
1997-01
To reset the monitor after an oil change, turn the ignition on. Press the "TRIP" button so that the "OIL LIFE" percentage is displayed. Press "RESET" and hold it for two seconds. The word "RESET" should appear on the monitor, then "OIL LIFE 90%".
Impala,
Monte Carlo
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator three times within five seconds. If the CHG OIL SOON lights two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHG OIL SOON light comes back on, the system has not been reset, repeat the procedure. Follow this procedure to reset the GM Oil Life System using the DE 100 Series Radio. Turn the ignition to ACC or ON and the radio off. Press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed. Press the SEEK up or down arrow to scroll through the main menu. Scroll until OIL LIFE appears on the display. Press the PREV or NEXT button to enter the submenu. RESET will be displayed. Press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second. Once the message has been reset, scroll until EXIT appears on the display. Press the DISP button to exit programming. A chime will be heard to exit programming. A chime will be heard to verify the exit.
Impala,
Caprice
1994
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Lumina,
Monte Carlo,
Impala,
Caprice
1996-00,
1996-99,
1995-96,
1995-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds. The light will flash and go out.
Corvette
1990-96
After an oil change, or when "CHANGE OIL" appears on the Trip Monitor, with the ignition on and engine off, press the "ENG MET" button (located on trip monitor) once. Press the "ENG MET" button again within 5 seconds. Within 5 seconds, press and hold the "RANGE" button (1990-1994) or "GAUGES" button (1995). The light will flash. When it stops flashing and goes out, the system is reset.
Chevrolet Suburban,
GMC Yukon XL,
Chevrolet Silverado,
GMC Trucks Sierra
2000-01,
1999-00
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However, if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Silverado, Sierra Trucks
1991-93
To reset the "CHANGE ENGINE OIL" message, turn the ignition key to the run position. Press and release the accelerator pedal three times within 5 seconds. If the light flashes for 5 seconds, the system is reset. Repeat procedure as needed.
on Dec 07, 2009 | Chevrolet Camaro Cars & Trucks
Have a 2003 dyna the check engine light comes on and the tail light goes out,the speedo quits working, and it feels like one cyl is dead for about 15 seconds, and when the light goes out all is well. can u...
To Get the codes you need to follow these steps:
1. While holding the odometer reset switch in Turn the ignition swithch to IGN. Make sure Run/Stop is in the run position. When you release the reset switch does Diag Appear? If yes press and release the reset switch, PSSPT should appear.
2. Flashing P= DTC's for ECM press an hold reset switch for more than 5 seconds you should have a device response.
3. To Choose the TSM/TSSM/HFSM Codes press and release the reset button a flashing S should appear. Press and hold the reset switch for more than 5 seconds you should have a device response.
4. To Choose the Speedometer Codes press and release the reset button a flashing SP should appear. Press and hold the reset switch for more than 5 seconds you should have a device response.
5. To Choose the Tachometer Codes press and release the reset button a flashing T should appear. Press and hold the reset switch for more than 5 seconds you should have a device response.
If any of the above have none displayed you are ok.
If any of the above have DTC's displayed then press and release the reset switch to see if any more are displayed.
After writing down the codes then press and release the reset switch and the part number of the module will be displayed.
Feb 28, 2011 | Harley Davidson FXDWG Dyna Wide Glide...
Presario f750us, push power button it lights up and goes right back off
I have seen another Presario desktop with this problem, and it was dust in the front panel jamming the switch on. Pushing the switch turned the machine on, but because it stayed on, after 4-5 seconds the PC shut down again.
I had to remove the front panel and clean out all the dust, then lubricate the switch movement.
Dec 19, 2010 | HP Compaq Presario F500 F700 and G6000...
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
It doesnt turn on just the blue light on the wheel
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 29, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Delll Inspiron 2200 Laptop does not power on
You have all the simpthoms of an overheating laptop.
For starters, get a vacuum and **** all the dirt from the fan or fans on the back/ bottom of your laptop.
Then turn on your laptop. It should stay longer than 5 seconds.
If this solves your problem, then you are lucky.
If not, you'll need to have your laptop serviced, and clean the heat sink, and have reapplied the heat transfer compund on the processor.
Not a big deal, and not that expensive either.
If this answer helps, please don't forget to rate.
Jun 22, 2009 | Dell Inspiron 2200 Notebook
Have a ws-42413 mitsubishi TV
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 08, 2017 | Televison & Video
Powers up temporaly displays goes dark
Your monitor has a bad back light. Send it back to your friend
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Denon AVR-1905 Receiver Logo
638 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
