Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Replacing Black and Decker 18" lawn mower blade
I purchased a new fan and blade for my Black and Decker mower, but I can't figure out the right order to place the fan, blade and washers.  Where can I find a figure showing the orientation.
    Scholar:
  • 121 Answers
Black and decker has a web page and 800 number which I can't locate rigth now
Posted on Sep 27, 2008
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
Aug 02, 2016 | Black and Decker USA Black & Decker MM1800...
No start on a mm 1800 18"
check the cord for cuts then check the safty engagement on the handle and make sure it disengages to cut thats about all you can do turn blade make sure turn freely not plug in after you will have to take it in
May 31, 2014 | Black & Decker Black and Decker Mm575 18"...
Black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
while unplugged rotate the blade a few spins to move the brushes if there stuck make sure the outlet is good and try another power cord
Aug 13, 2012 | Black & Decker Black and Decker Mm575 18"...
How to hold shaft when replacing blade
You should hold the blade while loosening the bolt that holds the blade.
Jim
Aug 05, 2011 | Black & Decker Black and Decker Mm575 18"...
I cannot remove the blade from my B&D MM575 mulching mower. The manual says to block the blade, then loosen the nut. However, when I block the blade and turn the nut, the shaft continues to turn,...
You can use a pipe wrench on the shaft and a regular wrench on the nut. Disconnect your spark plug and tip the mower onto it's left side. You will have to use your left hand to go down through the mower shoot to hold the pipe wrench and your right hand to unbolt the the blade attaching bolt, it should come off immediately.
Remember you may have to purchase a new blade holder, since your problem shouldn't occur if your blade holder was OK. GOOD LUCK.
Jul 28, 2011 | Black & Decker Black and Decker Mm575 18"...
Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
May 26, 2010 | Black & Decker Black and Decker Mm575 18"...
The mower vibrates hard I replaced the fan and
you could have a bend blade or bent armeture shaft if you hit something that hard
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
270 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
