Question about Karcher 2500 PSI Pressure Washer
2500 psi pressure washer?/
Casing broken at the back .where in scotland can i get one? and what is it called?
4 Suggested Answers
  • 548 Answers
SOURCE: leaking inside the casing. No pressure from the
sounds like the bladder or seals are shot they make a kit for this
Posted on Aug 22, 2009
  • 174 Answers
SOURCE: when I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Posted on Sep 24, 2009
cool78259
  • 228 Answers
SOURCE: I don't get a constant
Make sure that while you are running your pressure washer, other machines that pull
large volumes of water like a dishwasher or washing machine are not running. check and make sure
the hose you have tied to the pressure washer is not collapsing or has any kinks in it.
check the filter where your water hose ties in to your pressure washer, make sure it
is clean and does not have any debris or hardwater buildup, clean the tip at the tip of
the wand. if it is reduced in size by hardwater buildup, will not work properly, good luck!
Posted on Jul 12, 2011
On my brute 2500 psi pressure washer when I let go of the trigger it kills the motor. I changed the unloader valve and still does it . Any suggestions? Thanks
Excessive pressure can stall out a motor. Try reducing by adjusting unloader valve. Clockwise turn will increase pressure, counter clockwise turn will reduce.
Oct 30, 2016 | Garden
Where do i get a 2200 psi pump?
It depends on what you want the pump for, but at 2200 psi, I presume you are looking for something like a pressure washer pump.
Harbor Freight sells a 1600 or 2500 psi pressure washer
http://www.harborfreight.com/2500-psi-3-gpm-65-hp-212cc-pressure-washer-69734.html
If you need just the pump, here are a couple of websites to check out:
Pressure Washer Direct
http://www.pressurewashersdirect.com/power/pressure-washer-pumps.html
Northern Tool
http://www.northerntool.com/shop/tools/category_pressure-washer-accessories+pressure-washer-pumps?utm_source=Natural&utm_medium=Covario&utm_campaign=Pressure
And you can check on Amazon or eBay and see if someone is selling one there.
Sep 04, 2014 | Garden
Pull rope wont retracxt all the way
coil spring inside needs to be recoiled or tab is broken or off the hook
pull the rope assembly off and inspect/ repair or replace
Jul 24, 2010 | Karcher 2500 PSI Pressure Washer
How do you change the nozzle? We borrowed this unit and can't figure it out.
On most pressure washers the nozzle is inserted into a quick connect. Simply grasp the outside of the housing holding the nozzle and pull back. The nozzle will come out. While holding the spring loaded connector back insert a new nozzle and release. In some case there is a slot and the quick connect must be orientated so the slot lines up with a pin. If the end looks like this, then it is a quick connect. Grasp it and pull back. ecae845.png
Apr 24, 2010 | Karcher 2500 PSI Pressure Washer
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up , short spray then nothing - hot water comes shooting out the black valve - did something pop off?
The small black valve is called a thermal relief valve. If it is open you will have no pressure. If the water is getting hot enough to pop that valve, there might be internal problems with the pump.
Nov 22, 2009 | Karcher 2500 PSI Pressure Washer
When I squeez the handle the pressure surges.
Hi:
Sep 24, 2009 | Karcher 2500 PSI Pressure Washer
Where can purchase pressure fit axle nuts for my
These are available at Lowe's/similar.
Best regards, --W/D--
Aug 14, 2009 | Karcher 2500 PSI Pressure Washer
Poor pressure
i had this same problem on my pressure washer.the pump had some broken parts in it .i found my replacement pump on EBay.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
No pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
May 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
22 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
