Question about Microsoft Xbox 360 Console
Xbox 360 not getting video we have audio.
The switch is on t.v. we checked the wires. the console is not giving us a picture. the sound is fine. please help my son saved his money for this and the warranty was up THREE weeks ago.
  • trev0096 Jan 12, 2009
    my 360 is messed up it makes me mad the sound is on but not the picture I had this problem before and i stuck it into a different socket and it worked whats up with it
    Novelist:
  • 174 Answers
Its a similar problem to the 3rrod, the video is blank but audio still playing. the fix is the same as if you were doing a rrod console. replacing the heatsinks, reflow the whole board, replacing the heatsink paste and adding heat conducting pads to the memory chip. we can do this for you or can help you try to fix this yourself.
www.fixmyconsole.co.uk
regards
ian.
Posted on Feb 14, 2009
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
Mar 30, 2011 | Video Game Consoles & Games
My xbox 360 has sound but no picture wat is the problem
Check the audio video cables first. This could be caused by loose or incorrectly plugged in cables. If the cables are all plugged in firmly and correctly then the Xbox 360 has gotten a broken connection to the graphics chip. The Console will need to be professionally repaired unfortunately. If you are out of warranty or don't want to give Microsoft anymore $$ GATpro Repair Shop could help you.
May 27, 2010 | Microsoft Xbox 360 Console
XBOX 360 composite output works fine. Component
You say the component video is no good? Well this usually happens when it is wired up incorrectly, Ensure you have the right colors in the right jacks at each end, it is real easy to get mixed up... make sure Red goes to Red, Blue to Blue and Green to green, all alongside each other, NO ALSO using Component you MUST also run 2 more cables for the Audio, they are Red & White NOT the Red from the "Other" Video input, BUT the AV Red & White jacks, beside each other on the units. So all in all there are 5 cables taking the Video, 3 R, G, B. + The Audio, R & W.
Mar 02, 2010 | Microsoft Xbox 360 Console
Wont put out a picture or make sound when turned
turn off your xbox and switch the switch on the video/ audio chord and turn it back on. or just get a new audio/video cord
Nov 04, 2009 | Microsoft Xbox 360 Console
My XBox 360 has no picture - but audio is fine. anyone know what to do ?
sounds like a loose wire in the output?
are you using scart lead or HDMI lead?
try wiggling cable about or getting hold of a mate cable and checking that!
Aug 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Xbox sound but no picture
the problem all the time with the 360 is on the cable that gose into the back of the xbox has a small switch on the side of it my suspisions are its at hd slide the switch to tv then re set it this should work fine
Dec 02, 2008 | Microsoft Xbox 360 Console
Sound
I'm almost positive the problem is the audio cable. If everything else is working fine, you'll need to replace the audio/video cables. I've had that problem and I just bought the new cables and it worked like a beaut!
Still need help? Let me know!
Olivia~*
Nov 02, 2008 | Microsoft Xbox 360 Console
Xbox 360 console
try a different t.v it just might be the tv
Oct 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
