Question about Toshiba Computers & Internet
My screen has been rotate to the right.how can i fix it?
  • Amit Lakhtaria May 11, 2010
    Do u have n-vidia graphics card installed
  • 21 Answers
In the moniter thr is a menu button....if u click tht u can see so many option.. in tht option take the option called shape ...if u adjust tht shape u can correct ur size and it willl become normal
Posted on Sep 20, 2008
    Scholar:
  • 68 Answers
In the monitor there is a menu button.....if you press it you will get some options.....in that there is a option.....using that you can adjust it to the correct position.....try this...it will work 100%.....
My dell screen is sideways
On Windows 7, it says graphics options instead of monitor settings.
Typically, to fix this type of error, you would use ctrl+alt+up arrow key to flip the screen right side up.
(incidentally...
ctrl+alt+right arrow = flip to the right
ctrl+alt+left arrow = flip to the left
ctrl+alt+down arrow = flip upside down)
If that doesn't work, or if your keyboard shortcuts have been disabled, right click on the desktop background, click on Graphics Options, then Rotation, then Rotate to Normal.
Also, if you have Intel Graphics installed on you computer, the software might have reset the default rotation setting. To fix this, right click on the desktop, then click on Graphics Properties. This should bring up the Intel Graphics window. Choose Advanced Mode, and click OK. Find the rotation settings (right side, 2nd from bottom), and choose Rotate to Normal.
Feb 11, 2015 | Dell Inspiron Computers & Internet
Turn screen display
Since you have a Dell laptop, you can go about fixing it this way:
  1. Right click anywhere on your desktop screen; then look for and move your cursor on "Graphics Options."
  2. Then look for and move your cursor on "Rotation."
  3. Now click on "Normal." Then it should put your screen back to the upright position
  4. If you don't have the option to fix it like above (method #1), there are shortcut keys you can try. Press on these keys and hold them down at the same time: CTRL and ALT and UP ARROW. For whichever way your screen is rotated, by pressing those 3 keys at the same time should put your screen back to the upright position.
Oct 12, 2013 | Dell LATITUDE Computers & Internet
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
My iPad has a lock on it beside the battery sign how I can remove it so I can send emails
You probably locked the screen rotation,
to fix this:
  1. Rotate iPad so the display is in the desired orientation.
  2. Double-click the Home button to display recently used apps.
  3. Flick from left to right along the bottom of the screen.
  4. Tap the Screen Rotation Lock button on the bottom left of the screen.
  5. The lock will disappear
Jan 17, 2013 | Apple iPad (16 GB) WiFi Tablet PC
My login screen has turn upside down
Is it only your login screen? or is it the entire operating system? Does it fix after you log in?
Press [Ctrl > Alt > Up arrow] (all at the same time) to revert back to normal orientation. If it is only the login screen, then it may be a issue with the Operating System.
Aug 28, 2011 | Advent Netbook
My laptop display is upside down how do i fix it
Right click anywhere on the screen, click "screen resolution". Look for "Orientation" ,click the drop down menu to the right and click "landscape".
May 15, 2011 | HP Compaq 6720s Notebook
The screen is staying upside down when it starts up
Press "CTRL + ALT + arrow key"
Arrows:
Left - Rotates screen to the left
Right - Rotates screen to the Right
Up - Rotates screen to back to normal
Down - Flips screen
Aug 22, 2010 | Dell Inspiron 1501 Notebook
My screen rotated but i dont know how to fix it?
depending on your OS, go to your display properties (right click on desktop) settings there to rotate your screen back, usually display/rotate display
Jul 14, 2010 | ASUS m6n Notebook
My hp laptop back ground rotated and i am not sure how to fix it
right click on the desktop in a clear spot and scroll down to the video control panel, it may be the nvidia or the ati control panel. If you have the nvidia control panel, look in theleft pane and you will see an entry for "Rotate" screen. Click on this until the screen looks right. If you have ati, it may say screen orientation or something similar.
Dec 26, 2009 | HP w2207 Monitor
The display on my laptop is on a slant how do i fix it.
Depends on what angle it is!
R click on DESKTOP select GRAPHIC OPTION ROTATE
Please rate my help++++Thanks for using FIXYA
Oct 11, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
