Out of frequency LG500g
On starting without booting of os win xp.monitor displays error msg"out of frequency". on connecting monitor with other pc having win vista it works fine. i cant even open my bios. HF 27.9khz vF 62.0hz
operating frequency HF 30 -54khz vF 50 -120 hz
  • 65 Answers
15"LG Studioworks500g Monitor Supports Up to 1024by768pixel resiolution.
First U can check UR system res is High and than Go to Enable VGA mode on ur system.
Posted on Oct 07, 2008
I changed the screen resolution from 1024 768. while booting the monitor goes to power saver mode and displays "Out of Range 53.7KHZ to 60Hz. My OS is Win XP sp 3,
If the monitor is able to display the video after the computer boots, it may be something that you will have to live with.
But, you may be able to specify a different refresh rate based on the ability of your video card. Right click on the desktop, choose properties, then settings, and advanced button. On the new window, click on Adapter, then click on the Display All Modes button. The default for 1024x768 resolution is 60Hz, but your video card may offer another frequency which may be compatible with the monitor.
If you are unable to see anything after the computer boots, restart in safemode, then make the changes.
Is this an older monitor? 1024x768 is an industry default mode / setting. I am surprised that the monitor doesn't like it.
Jun 22, 2010 | LG Flatron L1515S 15" LCD Monitor
Our acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msgs are shown but once Windows XP starts, this error appears
Your resolution is set above what the monitor supports.
when computer is first starting up hit f8 to get to boot modes.
choose Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
When you are booted into windows you can then set your resolution to the highest that the monitor supports which is 1440x900
Let me know if this helps.
Mar 16, 2010 | Acer AL1916W 19" LCD Monitor
My pc powers up but never starts the monitor or run through a full boot up. all fans operate. changed monitor, same error. any ideas?
To Solve your problem kindly let me know
1. if you made any recent hardware changes. 2. Do you get any beep error msg or just one beep for clock check. 3. Have you tried removing RAM from its slot cleaning the slots and RAM and re-inserting. If not kindly do. 4. Have you tried booting through CD. Put your OS CD in CD drive and boot through CD.
Thankyou for using fixya free utility. Kindly rate my solution once your pc starts.
Jun 26, 2009 | NEC PowerMate ML4 PC Desktop
High frequency sound out of monitor
tell OS and monitor model...?
set this configration in win xp os...
1024by768 pix
32bit
and go to display properties=>advanced=>monitor=>change the frequncy....
some CRT monitors not support..
Apr 13, 2009 | Computers & Internet
Video output is upside down on Monitor.
Hi Koofah,
To fix the issue press Ctrl-Alt-Up. To permanently fix the problem go to:
Start >> Control Panel >> Display >> Settings >> Advanced
Where it is after that it dependent upon your video card.
Fixya!
Season's Greetings!
Chris (ziraffa)
Dec 23, 2008 | Toshiba Satellite A65-S126 Notebook
Hardware monitor error
Sounds like loose connection on your monitor card, if installed seperately, otherwise the wrong drivers installed.
Boot up in safe mode and uninstall the monitor drivers. and try and boot again.
Let me know if need further help.
regards,
Philip
Dec 01, 2008 | Sony VAIO Digital Studio PCV-RX560 PC...
No boot disk error when hard drive disconnected
Are you making the disk the "master" device when you plug it in to the PC?
Nov 02, 2008 | Computers & Internet
Lg CRT monitor model 500g 17inch -out of frequency
First, you did a great job of explaining and starting to identify the problem. You also eliminated a few things that we would have tried along the way.
PROBLEM DEFINITION: The real issue (as you may already know) appears that the operating system, specifically the software drivers for the video board and monitor, must be correct in order for the monitor to work. In other words: there are three computers that must be able to communicate with each other - the main computer, the video board computer (microprocessor) and the monitor's computer (also a microprocessor). Think of the drivers as the programs for each of the microprocessors. The message you are getting says that one of the three programs is sending data to one of the other programs and that the receiving program is complaining that it is "talking too fast to understand".
So, which one? Since you are not having any problems with Win98 or 2K then it is not a problem with the monitor (or so it seems). Since each Windows operating system must load its own driver, and many times these drivers are not the same (actually the "kernel" is if you think of them as programs for the microprocessors) because they must talk to the operating program too. I'm puzzled about the "...safe mode...didn't work..." comment since safe mode doesn't load the drivers on purpose. Maybe it worked at first and you didn't change anything so it didn't work when you logged back on without safe mode?
POSSIBLE SOLUTIONS:
1. Start up in Win2000 and look at "properties" for the video board and monitor. Use "advanced" if necessary and write down all of the driver names, the make of the vidoe board and especially the "frequency" of the monitor that it "thinks" it is. If it is "auto" then see if there are any other choices (50,60,65,70,72 and 75 are all popular sweep frequencies). Note that the video card AND the monitor must be able to communicate at the SAME frequency. One of them (or both) can be on "auto" but one can't be on 60 and the other on 72! This will produce the error message you describe.
Now, try to start up your WinXP (safe mode if possible) and fix (match) the properties/frequencies. You will have to bring up the control panel to do this since the "properties" selection is locked out in safe mode.
2. If this doesn't work then it might just be a program that is loading during startup. Check the "run=" statements in the Win.ini and system.ini files for WinXP. Remove or comment these out. An older game or application that didn't work on WinXP may try to grab the video before the system would start. Eliminate, or comment out if you don't want to eliminate any that you might want to keep, any program that you suspect or just don't have a clue what it does. Suspect programs that load on startup are virus checkers that were not written for XP.
3. Save, preferably on a removable device (USB thumb drive) your current video card and monitor drivers for WinXP as a backup. Log in using Win2K, download current drivers for your video card and monitor, also onto the thumb drive. Then, delete the drivers from the device manager. When you restart it should say "found new device" for both the video card and the monitor. It should then ask for the drivers. Point it to the thumb drive and load the new drivers.
Please rate this solution and let me know how it turns out...
Jul 17, 2008 | Computers & Internet
Computers & Internet Logo
492 people viewed this question
David Payne
David Payne
