Question about Gateway 450SX4 Notebook
Gateway Logo , two minutes
How do I reduce the time the Gateway Logo remains during bootup
My 2006 Buick lacrosse reduce power light came on today--what does that mean
Reduced Engine Power
Refer to Throttle Actuator Control (TAC) System Description in Engine Controls - 3.6L or Throttle Actuator Control (TAC) System Description in Engine Controls - 3.8L
TAC System Default Actions/Reduce Power Modes
There are 2 reduce power modes that the engine control module (ECM) can default to if an error is detected in the throttle actuator control (TAC) system. If an accelerator pedal position (APP) sensor 1 or APP sensor 2 circuit fault, throttle position (TP) sensor 2 circuit fault, or if a TP sensor 1 circuit fault is detected with some APP angle, the ECM goes into one of the 2 reduce power modes. In this mode, the engine torque is limited so that the vehicle cannot reach speeds of more than 100 km/h (60 mph). The ECM remains in this reduce power mode during the entire ignition cycle even if the fault is corrected.
If there is a condition with the throttle actuator control circuits, throttle actuator command vs actual position fault, return spring check fault, or a TP sensor 1 circuit fault, the ECM goes into the other reduce engine power mode. In this mode, the engine speed is limited to 2,500 RPM and the 3-6 fuel injectors are randomly turned OFF. At this time the Reduced Power indicator is commanded ON. The ECM remains in the reduce power mode during the entire ignition cycle even if the fault is corrected. Observe, if a TP sensor 1 or throttle actuator control circuit fault is present at the time the vehicle is at idle, with no accelerator pedal angle, the engine may stall.
Jun 21, 2015 | Cars & Trucks
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
We're running SonicWall Enforced Client on a Windows 7 64 bit machine. Upon bootup, the system hangs for 7-10 minutes while the McAfee agent updates. During this time the PC is not usable. If the user...
..UNINSTALL McAFEE!!!!!!!!!!
There are SO many FREE antivirus-antispyware-antimalware programs that are as good OR BETTER than Mcafee..
.. all my experience with McAfee is that is that it SLOWS DOWN any machine its on...
Aug 08, 2017 | SonicWALL Enforced Client AntiVirus and...
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I can't reboot. help!
Hi, I need full descrition of problem to help you, but try booting in safe mode, by pressing the ESC or Del key during bootup. From here you can reset your system to a time before problem started.
Aug 03, 2010 | Gateway 832GM PC Desktop
FPD2275W No PC or On Screen Menu Display
Bad caps, be REAL CAREFUL when take the bezel out, you can easily damage the small ribbon cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Jul 28, 2009 | Gateway FPD2275W LCD Monitor
Bootup
a bad power supply or a hairline crack in the mobo
Jun 04, 2009 | ASUS (P4BGV-MX) Motherboard
My SVA monitor 5 blacks out after 5 seconds
use f 8 to go to safe mode then set the resolution at the very least liek 8 bits or whatever the lower=st is and save it then restart in normal mode and then play with the resolution in display settings to get to the ma your video card will support.
Jun 19, 2008 | Gateway FPD2275W LCD Monitor
Long boot up time with Vista
ok what you need to do is clean up your registry and then defrag your registry and hard drive
Download TUNEUP UTILITIES and use that, it has a trial version in case you cant afford to buy it
Dec 30, 2007 | Computers & Internet
Gateway
The problem is inside the CPU... Open the case and check the voltage of the battery, a small button cell, it should read as 3V.
Check also the heatsink of your processor it might need dusting.
Now try turning it on...
Get back to me and tell me more about it.... ;)
Dec 11, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
