Question about T-Mobile Sidekick® 3 Cellular Phone
Master Reset I followed the proper instructions to do a master reset and everything was fine so far. At this point the screen says Waiting for Activation, it has been like this for the past 3 days. What do i do now?
CoNTRoL + L SHoULD REMOVE THE SCREEN
Posted on Sep 24, 2008
How reset
to perform a master reset on nuvi 200 and 205 series devices:
note: a master reset will erase all favorites1 and will restore your device to the default factory settings. if you would like to back up your favorites to your computer, you can find instructions to do so here.
  1. start with the device off and unplugged from power
  2. touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. continue touching and holding the lower right hand corner of the screen then power the device on
  4. release the power button when the device powers on
    • you will see a new message: "do you really want to erase all user data?"
  5. remove your finger from the touch screen when this message displays
  6. touch yes
    • if text language is not in english, this is the button on the right
the device will now reset. follow the on-screen prompts and then place your device in an area with a clear view of the sky until it acquires satellites.
1although the master reset will erase all saved favorites, any loaded custom points of interest will remain intact on the device.
Aug 12, 2014 | Garmin Nuvi 205 series
Motorola factory reset
Apps > Settings > Backup & reset . Factory data reset
To Perform a Reset
  1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset
  5. Touch Reset Phone
  6. Touch Erase Everything
For older phones: Master Reset or Master Clear
Mark
Motorola Support
Jun 29, 2014 | Motorola Cell Phones
I forgat my password.how can i resat my password?
You can Unlock the Mobile from the Security/Password lock using the Master reset code.....once my Mobile was locked by security code,I forget the Security code,i used the Master Reset Code to Reset it from security lock,I got the Nokia 6600 Master reset Code at http://www.onlinegsmunlock.com/unlocking-services/rs7wp6/ at Reliable cost and Unlocked it from the Security code,.So You can Check master reset Code for Your model mobile in that list...
Nov 03, 2010 | Nokia 7230 Cell Phone
My Garmin nuvi 205W was working fine but I wanted to update it on the computer before a family trip. Update seemed to work fine but the unit would not turn back on afterwards - not in the car, by USB, or...
Have you tried a master reset??
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Nov 24, 2009 | Garmin nuvi 205W GPS Receiver
SONY DAVHDZ278 BRAVIA HOME THEATRE SYSTEM SURROUND SOUND PROBLEMS
OK, it is called Cold Reset
Turn unit ON and press following 3 button on same time..
STOP - EJECT - POWER
Display will show Cold Reset briefly and DAV-HDZ278 is reset to default settings.
Thanks.
Aug 20, 2009 | Sony Audio Players & Recorders
How do you do the master reset?
you must hold the up button and power button at the same time....instructional screen will appear
Jun 17, 2009 | Samsung Blackjack SGH-I607 Smartphone
Motorola q9c smartphone is frozen on windows mobile screen. this happed when i updgraded and had a new phone activated. is there any way to unfreeze the phone. have tried teh soft reset with battery with...
master reset the phone by hold the center key and the power, then follow onscreen instructions, let it sit on the windows mobile screen, before you master reset try turning the phone off, and taking out the memory card, then turn back on, if same thing happens....do the master reset
Dec 29, 2008 | Motorola Mobility Q9m Smartphone
My krzr screen shows everything backwards!
Try a master Reset.
To perform a master reset on the handset, follow these steps:
NOTE: A master reset restores the original factory settings and can erase all downloaded content, including ringtones, camera images, contacts stored in the handset memory, and Java™ applications. It does not erase data stored on the SIM card or memory card. Back up all necessary data on the handset memory before proceeding.
  1. From the main screen, select Main Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Initial Setup.
  4. Scroll to and select Master Reset.
  5. Enter the security code.
    • NOTE: The default security code is 000000 (six zeros).
  6. Select OK.
  7. Select Yes.
  8. Press the red End pattlnk_5142007_1444-redend.gif key to exit and return to the main screen.
Dec 09, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Master reset
If by master reset you mean wipe out everything and make it look like you just took it out of the box.
Simply put in the "Restoration CD" that came with the computer.
(If you still have the instruction booklet then instructions are in there I believe)
Mar 14, 2008 | Computers & Internet
Maps and POI's are gone
You can try a Master Reset, but be aware, this will ERASE ALL OF YOUR FAVORITES. To do a master reset, turn the unit off. Press the On button and the bottom right of the screen at the same time. Release the On button, but continue to press the screen until the unit asks if you are sure you want to reset. Press yes. This MAY help.
Oct 12, 2007 | Garmin StreetPilot C330 GPS Receiver
T-Mobile Sidekick® 3 Cellular Phone Logo
49 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
