Question about Lexmark C500n Laser Printer
Set transfer roll
Printer says "set tranfer roll". How do I do this?
  • acik Apr 05, 2012
    please send me the service manual book to;
    alex@aevista.com.my
  • LXK Chris
    LXK Chris Apr 06, 2012
    If you get the set transfer roller message on your printer, please try to check Turn printer off, and check transfer roller contacts. Please make sure to verify that it is attached properly to the frame. If the contact is damaged, a replacement of the transfer roller assembly is needed.
    Part #:40X3418 ( Transfer roller assembly)
    Please visit the site below to check for the availability.
    https://parts.lexmark.com/wpo-catalog/US...
    Hope this helps.
    For further assistance I would suggest you contact Lexmark Technical Support Center.
  • 300 Answers
Your printer doesn't recognise the transfer roller, it is either not fitted properly or one of the contacts have slipped off the frame.If you would like i can email you the service manual (it has some pictures of this in it) if you would like me to please reply with your email address.
Posted on Sep 21, 2008
  • arreewin Nov 12, 2010
    I have the same problem set transfer roller. my email id arreewin@yahoo.com. Please email me the solution.
I am having this problem at work. Could someone send me the solution @ steve.montgomery@exel.com. It would be appreciated.
Posted on Jan 24, 2010
Please if you could send me the service manual to 78ody@otenet.gr thanks!
Posted on Dec 17, 2009
Envia favo para
marcossserafim@hotmail.com
Posted on Apr 15, 2015
Oh yes please!! E-mail to polly.l.lariccia@delphi.com. Thanks!
Posted on Sep 26, 2008
  • chloejade86 Nov 30, 2011
    Would u possibly be able to send this diagram to me? I am in a tizz with the same issue! :(
    chloe.turner86@gmail.com
How do I set my tablet to put everything on my mico card?
Not all applications can be transferred to micro card. To know and transfer a particular application
1) go to settings then to application manager then
2) select the application you wish to transfer. If that can be transfer it will show in application info to tranfer to sd card.
3) click transfer to sd card.
May 26, 2015 | Nextbook Premium 8 Se Android
I have a Rimage Everest ii printer that prints 3/4 of the lable and the rest of the lable remains on the transfer roll
This is usually a set screw that has loosened up on the heat transfer roller. There is a gold colored gear that rotates the heat transfer roller, when the screw backs out the roller does not turn causing the issue you are seeing.
John Norman
Max Optical llc.
www.maxoptical.com
Aug 13, 2013 | Rimage Everest Autoprinter Thermal
How can i tranfer my videos to my computer I got the USB cable but cant seem to get the transfer???
Make sure that you set the phone to be accessible as an external drive, then you should be able to do any transfering. also, you could always just e-mail them to yourself as attachments and download them directly to your computer
Mar 23, 2010 | LG Vu CU920 Cellular Phone
My wife tried to print on T-Shirt tranfers meant for ink-jet printers, and they melted onto the fuser roll, and it stinks. I need to remove the fuser assembly and clean it, but could use some instructions....
This might help. I did the same thing with my laserjet printer.
Staples has laserjet cleaning sheets. I ran several sheets through the printer after I pulled most of the transfer paper out.
The sheets are one use sheets so, you will need a few.They are impregnated with cleaning fluid on textured paper.
These sheets clean the entire paper travel path.
Dec 12, 2009 | Brother MFC-7820N Laser Printer
How to install the transfer roller
On the front right side your going to see a lever with the letter "A" pull that lever up and that opens the whole fron cover. If you look inside the front cover you will see the transfer roller
"TRANSFER ROLLER 108R00592" . Once you have ID the tranfer roller you will notice tan tabs one on the right and one on the leftside. Push those tabs inward this will cause the transfer roller to unlock then just pull up . Then to install alight the black tabs on the bottom of the tranfer roll to the same possition as the old one and just press down and it should lock in place and that is it. Good luck.
Oct 29, 2009 | Xerox Phaser 6250N Printer
Not sure which part that may need to be replace
tranfer belt is a large mylar black belt.
transfer roller is a skinny gray foam roller
Mar 13, 2009 | HP Color LaserJet 4550n Printer
Transfer unit
You need to reset the counter, instructions should have been in the box.
Jan 15, 2009 | HP LaserJet 3700n Printer
IRON ON TRANSFERS
Iron-on paper size is A4. Use Plain Paper for the type.
Important: Image will end up backwards when ironed if the Photo Options screen does not have an option to FLIP the image.
Nov 17, 2008 | HP PSC 2355 All-In-One InkJet Printer
Kodak 5100 all-in-one printer
if u plug it in and beeps 3 time when plugged in means that it isn't compatable with the printer if doesn't beep 3 times call 1-800-235-6325 cameras option 12 onezoom 13
Mar 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing t-shirts
Unfortunately, you can't print directly on to t-shirts. You have to print onto transfer paper, which you then iron on to the shirts.
Regards,
Javabytes
Nov 18, 2007 | Compaq A3000 All-In-One InkJet Printer
Lexmark C500n Laser Printer Logo
964 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
