Question about Kitchen Ranges
Main oven not firing up just stays on low heat
  • Anonymous Jan 04, 2009
    My gas oven fires up initially but it stays on low fire. It is supposed to blow gas creating a big flame and heating up. However it will not. Does anyone know where to look or what the fault could be?
    Many thanks
  • 116 Answers
Hey roystondyer0
You need to give us a little more info
Is this an electric or gas unit (I assume gas "from firing")
what is the model number
When you say on low heat is this the glow you see inside the oven
post a response
Regards
Posted on Sep 20, 2008
Gas valve wont open in my oven
call your local repairman .
Nov 15, 2016 | Ovens
Dcs oven wos130 wont reach set temperature on bake
Good afternoon Steve!
The answer may depend a bit on what you mean by 'stops heating'.
  • One interpretation could be 'the heating shuts off, and the oven goes back toward room temperature
  • The other would be that it heats up, but it heats to a certain temp and then stays there. it's just not as hot as it's supposed to be.
If it's the former, that sounds like something is overheating and an interlock is engaging because it's interpreted as 'I'm too hot where I shouldn't be, and I should shut off before I cause a fire. I'd leave that to a better trained service tech.
If it's the latter, then it'll depend on how low it is. If it's way low, then there's a couple possibilities:
  1. The heater element is defective, and even at the full current draw the oven can run, it can't get any hotter than that upper temp. This would mean replacing the element.
  2. The temperature sensor in the oven is defective or mis-mounted. There should be a temp sensor inside the oven cavity. if it's disconnected, or, say, bent out of place and much nearer the bake element then it should be, then the heat coming direct off of the element may be fooling it into thinking the oven is hotter than it really is. this could mean replacing the temp sensor, or just re-mounting it to proper position.
If it's just a bit low, then there could just be a calibration problem. If you look at the manual here
DCS WOS 127 Use And Care Manual Child Safety User Option you can see how to adjust the calibration up or down in temperature to, hopefully, match the oven thermometer you're trying to use as a check.
Hope this helps!
Good Luck
D
Nov 18, 2015 | DCS Wot-130 30" Wide Single Electric Wall...
We have a dcs 48 inch range/oven and the main oven does not heat. The broiler does and the small side oven heats. Any advice?
You don't say if it lights up! If it lights up and stays on low it's the thermostat that's at fault, they are not adjustable and will need to be replaced.
Mar 09, 2014 | DCS 48 in. CP486GDSS / CP486GDSSL /...
My toaster doesn't give enough heat to use it
follow this test with multimeter, and fix it. God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord.. If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements
Nov 08, 2013 | Hatco Conveyor / Toaster
Heat is low
please make this test with the multimeter.God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord If the oven doesn't work on its toaster and oven functions, test the main switch As needed, check the fuse .
If the toaster oven stays on when the door is opened, check the main switch (). If the oven doesn't heat, test the heating elements.
Euro pro to241r
follow this steps and fix it. God bless you
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
Oct 10, 2013 | Toaster Ovens
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
Gas oven not firing to correct temperature
if the flame in the oven is staying on low you will need to replace the fsd.
Sep 28, 2009 | Ovens
Oven heating element stays on
If element stays on even with oven turned off you probably have a bad main board. A relay on board is probably stuck on. If it stays on, but at a reduced heat...not getting red hot, it may be from a shorted wire causing 110 volts to get to element.
Nov 02, 2007 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
