Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Nomad Zen Xtra Headphone Jack Fix
My headphone jack is broken and I really need to repair it. Unfortunately, i can't open the small screws on the back of the jukebox and i tried almost everything, but it still won't work. Not even precision screwdrivers smaller than the screws. The screws simply won't turn at all, it seems they are stuck.
What can I do?
  • chattyfurrow Sep 24, 2008
    thanks, that did work.
    now that i took it apart, the headphone jack is loose so how would i go by to fix it n get my sound back?
  • chattyfurrow Dec 18, 2008
    theres a nut that holds it to the housing
    President:
  • 1,263 Answers
The precision screwdrivers do n't have enough torque to loosen the screws, so you have to get a longer screwdriver with a very small tip a #1 size . the longer shaft with bigger handle will allow for more torque to loosen the screws. please rate this
Posted on Sep 20, 2008
  • Ronald Mueller
    Ronald Mueller Sep 24, 2008
    are there soldered ends? or is there a nut that holds it to the housing?
My ipod classic is only playing out of 1 headphone, it is the same with all headphones
Step 1:
Your trusty iPod has been a close and reliable friend for a long time but one morning only the sound of air comes through the headphones. The likely culprit is a loose or broken headphone jack that is in need of repair. Rather than spend an exorbitant amount of money to have someone fix it you can easily make the repair on your own and have your iPod friend back. Read on to learn how to fix a broken headphone jack for a fifth generation 30GB or 60GB iPod video.
Open the iPod case with a small flathead screwdriver by slipping it under the centerline of the case. You will find a series of clips you have to release in order for the case to open up about an inch. Locate the headphone jack connection and verify that there are no broken wires. Fix broken wires quickly by twisting the wires back together and wrapping with electrical tape. Test the iPod for sound by connecting your headphones to the jack. Replace the wires completely if you find static coming from the iPod jack. Fold a business card twice so that it wants to unfold and slip it into the case over the blue sponge. This creates the pressure needed to hold the jack in place and allow a solid connection. Push the case together without engaging the clips on the side and test to make sure the jack is now working. Try a thicker business card or fold the first one again to get enough pressure onto the jack connection if the first card didn't fix the problem. Press the case fully together until the clips click into place. Use extra care when inserting your headset to ensure the jack remains in place.
DigiExpress - iPod Video / iPod Classic Headphone Jack installation
http://www.youtube.com/watch?v=MXXgV6YNGkQ
Feb 22, 2013 | Apple iPod classic MP3 Player
My headphone jack broke inside of laptop how to
Unfortunately this can only be repaired by a shop.
Oct 30, 2009 | Acer Aspire 3050-1733 Notebook
Elizabeth needs you
You need to say what the problem is. If it's a broken headphone jack probably someone can help. If it was flattened by a 600 lb woman stepping on it I think then no. Dropping it on a concrete floor is not good either.
success fishing often depends on the quality and appearance of your bait. In this case the hook is bare...
IR8D8R
Dec 14, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Nomad Jukebox Zen Xtra
First thing i would do is make sure your at the current firmware.
Dec 18, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Headphone Jack
if you can get into it easily you can re-solder the point at which the contact is broken off the board. This is a common problem. If  you do not know how to solder, or are not good at opening these (it will void any remaining warranty) refer it to someone locally that does.
Oct 28, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Loose earphone Jack on sony mp3 player NW s705f
you will need a very small soldering iron (pencil) and solder and solder the jack back on the board
· http://www.noboundrees.com/micro_fix/
· http://www.pcpages.com/thebishop/nomadfix/
· http://www.instructables.com/id/Zen-Micro-Headphone-Jack-Fix/
Oct 17, 2007 | Creative Labs Zen Micro MP3 Player
Loose earphone Jack on sony NW s705f
Flaky Headphone Jack
Unfortunately the Zen Xtra was designed poorly and this problem tends to happen sometime along the life of the product.  As you suspected, the problem is the solder joint and the only solution is to open the player and resolder it yourself.  As long as you are careful, you shouldn't have any problems.  The hardest part is trying to get the thing back together after you took it apart:  Just be sure not to loose any of the pieces.  Detailed instructions with photos are located here:
Oct 14, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Headphones
Headphone jack repair
Sep 14, 2006 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
232 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
