Question about Zoom (5590-00-03) Wireless Router (G66115)
HP laptop won't always connect to zoom router
1. 1st my Internet Provider said it must be my wireless card. I replaced the hp wireless card it didn't help
2. i removed all firewalls - that didn't help
3. I brougt in my IT person from work and they say it's probably a problem between the zoom router and hp wireles card They updated all software and hardware and it connected BUT now it still
4. Sometimes connects fine and sometimes it won't connect.
5. regardless of whether or not it connects I always have 5 green bars showing excellent. I even sat it next to the router just to be sure there's no wall interference and it is the same. One time it connects and another it doesn't,
I'm simply frustrated--Anyone have a solution?
  • noname7001 Dec 23, 2008
    I have same problem. I have an HP G60-125NR laptop. Sometimes it will connect, sometimes it doesn't. There are times when it connects like for 10 mins then disconnects for 5 mins and repeats. I also see 5 bars of signal. I'm in the same room as my router. I thought it was my computer but when I had friends over, they all had the same problem. I wasn't sure whether it was HP or whether it was windows Vista. My sister's gateway laptop works fine.
  • r1227 Feb 01, 2009
    Where can you find the location to change the channel that the netwrok is using?
    Problem Solver:
  • 13 Answers
Every time I have ran into this issue it is because of wireless interference. Try these steps:
1) If you have a cordless phone, try turning it off (unplug the base). Some cordless phones operate on the same frequency that your wireless network does.
2) Change the wireless 'channel' your network is on. There are 11 channels. For best results, choose either 1, 6 or 11. Most wireless routers come preconfigured on channel 6. So if your neighbor has wireless and is operating on the same channel, your leptop may be getting confused.
3) Make sure your laptop and wireless router are operating on the same encryption level (WEP, WPA or WPA-2) and speed (A, B or G). Some older laptops do not support WPA-2.
Good Luck!
Posted on Feb 01, 2009
Laptop running windows vista won't connect to router in Europe.
You need to call the internet provider. They more than likely have a different protocol to set up in order for your internet to work.
Jun 25, 2012 | HP Computers & Internet
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
My hp lap top wont connect to the internet through the usb the ethernet or wireless and it was working fine until 24 hours ago. I think it may be the network adapter. I re installed the driver for it but...
Try turning off the wireless router fo 30 secs and then power it up again. When the LEDs light up, then boot up the HP laptop.
If this doesn't work, then check the laptop to see if the wireless router issued the HP laptop with an IP address. to do this - click on Start - Run - type cmd and press Enter. This will open a DOS command box, then type ipconfig and press Enter.
If the IP address returns 0.0.0.0 then the wireless router didn't issue the HP with an IP address and either the wireless router is faulty or the wireless card is faulty or it has lost its LAN configuration.
If the wireless router LEDs are all on, try connecting a LAN cable direct to the LAN port on the router and the laptop to see if it connects to the Internet. If it connects then install the latest wireless card driver and configure it with the wireless router's settings.
Jan 25, 2010 | HP Computers & Internet
Presario 900 laptop what internet dongle do i need to connect to internet.
that completely depends on what kind of internet service you have.
The laptop has a Ethernet connector so, if you have a internet connection in your home you should be able to connect it with a wire to the router or the modem and it should work.
Sep 11, 2009 | HP 285527-001 - Compaq Presario...
I have an older HP laptop with no wireless capability. We have DSL with the wireless router connected to our desktop. The only way I can access the internet is by putting in the AT&T air card. I don't want...
You can connect to the Internet using your DSL wireless router by several methods.
1. If your HP has a LAN port the you can connect to your wireless router with a LAN cable (provided you have a spare LAN port on the router.
2. You can use a USB wireless adapter to connect to the wireless router.
3. You can use a PCMCIA wireless card to connect to the wireless router.
Both the wireless USB and PCMCIA wireless adapter are approx. $50, my preference is to use a PCMCIA adapter, it leaves the USB port free for other devices,such as USB memory sticks, especially if the laptop has only one USB port.
Jan 17, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Hp does not support zoom wireless set up
For X6:
Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 10, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Laptop won't connect to wireless
Hello :-)
Try going into device manager, and uninstalling your wireless network adapter.
Reboot your PC. It will automatically reinstall your wireless network card.
Now try your wireless connection. This often solves random wireless issues.
Jul 08, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Zoom (5590-00-03) Wireless Router (G66115) Logo
411 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
