Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE profile gas range
When I press start button after selecting bake, circut braker gets out.
  • 750 Answers
Hello zjaffri Welcome to fixya.
I'm Huuum and happy to assist you,
You said, when I press start button after selecting bake, circuit breaker gets out.
this means there is a short circuit some where in your range! If you are not able to find and repair it your self ,you may need service to diagnose this!
Please do not for get to give a rating before you sign off!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old range
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your range,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your ranger is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of ranges you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Thank You, HUUUM
Repair or replace?
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Posted on Sep 24, 2008
GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Jan 28, 2010 | GE Profile JGS968 Gas Kitchen Range
"door" appears when selecting bake or broil.
First take the door latch lever and push it to the left with moderate force. This may re-align the switches inside. If that does not correct the problem replace the door latch switch.
Apr 02, 2009 | GE Profile JGBP79 Gas Kitchen Range
No Bake; everything else works
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
Jan 28, 2009 | GE Profile JGS968 Gas Kitchen Range
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Dec 02, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE JGB920 Gas Range problem
if not post your email i will send you the service manual
Mar 15, 2008 | GE Profile Spectra JGB920 Gas Kitchen...
Buttons on Control Panel not working for my GE Profile Gas Range
Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
Thanks
Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
120 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
