Question about Dishwashers
Dirty Dishes in top rack, Sears Kenmore Mod. 16032 - Fixing Pump Impeller?
Recently, I've noticed that bits of food are winding up on my dishes in the top rack (having washed off salad bowls in the bottom rack). After reviewing other peoples' issues with the same problem, several experts have diagnosed it as a Wash Pump Impeller problem. Don't know if they're right, but is there a guide to tearing down the machine to check it? I haven't been able to find a step-by-step process for this, and any guidance will be welcome. Also, is there a guide to disassembling the tubes carrying water from the pump to the upper wash arms?
    Top Expert:
  • Dishwashers Master
  • 40,483 Answers
Check YouTube for something similar.
Posted on May 02, 2017
SOURCE: my maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Posted on Dec 21, 2009
  • 578 Answers
SOURCE: top rack of dish washer does not have enough water
Trouble shooting here... but the same pumb that circulates water... vents it.... So, if the vent valve is clogged with food debris, then you would not retain enough water to wash all the upper rack dishes...
I recommend inspecting the exhaust tube port of the pump (a selenoid is the operating device for that valve). Be sure that it is able to operate freely (close all the way. Otherwise, it is just the pump intake!! only have already eliminated the rest (GOOD JOB)
Posted on Dec 31, 2009
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Kgt1962. I have same problem with the lower rack not cleaning. the lower wash arm just sits on top of the plastic opening at the supply pipe. it just flops around. Is this normal?
Posted on Mar 16, 2010
  • 2468 Answers
SOURCE: water not getting to upper wash arm
remove the roller rack plastic end caps this will let you remove the upper rack,then you can replace the whole wash conduit from the bottom sump all the way to the top,also if theres a middle(center arm) this has a horn on it that is to seal when the rack and door are in and closed,but after while the water wears out the plastic o-ring and they leak and you lose water pressure to the top wash arm
Posted on Apr 01, 2010
  • 949 Answers
SOURCE: Dirty dishes, pump acid wash.
I would not recommend using acid in a dishwasher it could lead to premature seal failure and damage the internal components.
There are cleaners that can be used that are dishwasher safe such as Lemi-Shine, Glisten, Rinse Aid dishwasher cleaner etc. Vinegar works pretty good too.
Depending on what the symptoms were a pump cleaning may be needed, before you act check out these tips I put together, feel free to send me a message back with any questions.
Posted on May 06, 2010
Dishwasher leaves upper rack dishes dirty. It's Whirlpool Quiet Partner II
Your water pressure is not high enough in the dishwasher to wash the dishes on the top rack. The most common reason is that the pump in your dishwasher cannot pump fast enough to keep the water pressure up. That is because the shaft that drives the pump impeller also drives the macerator cutter that grinds up bits of food fine enough for it to pass through the screen and out to the drain. Over time, small bits of bone, broken glass, eggshell, and other items that are too strong to be cut up by the cutter end up sitting in the area where it has to spin, and they prevent it from spinning fast enough to pump enough water to the top rack with any pressure. It is simple enough to repair. You need to take out the racks, remove the bottom arm and clean out the little macerator. Once that is done, it should work great again.
Feb 22, 2011 | Whirlpool 24 in. DU900PCD Built-in...
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
On normal wash cycle the dishes are still greasy and there is food debris on the inside door the machine has water and runs through its cycle but the dishes especially the top rack is still...
Depending upon the age of the DW, you may have a restricted or bad pump. You also could have a restriction in the drain line that goes to your sink.
Oct 13, 2010 | Kenmore Dishwashers
Not cleaning properly
take a good look at the two spinning washers they are easy to remove i would suspect they are clogged clean and replace.adrian,,,,
Jul 14, 2010 | Kenmore Dishwashers
The dishes/glasses on the top shelf are not getting clean
Here is a link to a procedure I put together to clean out your pump. A plugged up sump is the most common reason for poor washing on the upper rack.
Let me know if this helps.
Apr 30, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher kenmore 16789
It sounds like your wash pump impeller might be clogged. The first symptom of this problem is poor cleaning capabilities and food left on dishes. You will need to remove the spray arm assembly to access the reservoir below the spray arm. More than likely, you will find debris clogging the the wash pump impeller area. As a general rule of thumb, you should not put anything into dishwasher that still has to be chewed. You don't have to prewash your dishes, just scrape them real well. Most detergents still need to oils and residue from food to activate the cleaning agents. If you prewash, you simply defeat this purpose. Some things that should NOT go into a dishwasher are lemon seeds, orange seeds, pistachio seeds, popcorn kernels, chunks of meat, bacon, tooth picks, chicken bones, match sticks, bottle cap liners, jar labels, etc. These are a small example of SOME of the things I have personally found in the wash pump. It doesn't take much to clog the pump, and the chopper assembly is not to be considered a disposal. I hope this helps you. Let me know if you need any further assistance.
Jul 25, 2007 | Kenmore 16879 Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
