Question about Samsung CLP 300 Laser Printer
Printing is faded or missing from top 1/3 of page
Fixed a paper feed problem with help here the take up roller was indeed damaged and I unclipped it and turned it over to get a fresh side that wasnt worn no more paper jams. I little tricky to get at but not mpossible! However the printer is now missing printing on either top 1/3 or bottom 1/3 or middle 1/3 of paper. It cam be fine at top and bottom and then faded or mssing in middle as if it hadnt picked toner up or fixed it on. This missing section varies over time to various points on the paper. the horizontal missing sections are either at the top bottom or middle with the rest printing ok. I would seem like a roller kind of thing given that some sections are ok. Is it just me or are there a lot of difficulties with this model. My experience with two of them is lots of jamming my wife calls it the Bob Marley printer as it is always jamming. I have found the used toner full to be the main culpret and refuse to pay a tenner for a plastic box every three months! So I just stick the vacuum cleaner nossle on the end of the contaner **** out the dust and away the jams go. Any help with the problemmuch appreciiated and if anyone wants to know in detail how to flip the feed roller rubber let me know
Sounds like a flat spot :}
Posted on Sep 26, 2008
Dell 1110 faded print left side
If you have trid a different toner cartridge, then I would first try a new drum (not sure if toner & drum are in same cartridge, some are so you will have to check that) If not that, then I would suggest the transfer roller bar would be my next suspect if the printer has a lot of copies done on it.
Jan 13, 2013 | Dell 1110 Laser Printer
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
Hello - my Brother DCP 330C printer is printing horizontal faded lines on both color and Black and white copies. I have changed the toner in all areas but still no change. Could the problem be with the...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
Paper feeding problem
3 possibilites.
1.. the paper pick up rollers are jammed
2. you have a small piece of paper stuck inside
3. pickup roller gearsor solenoid are damaged
Apr 17, 2009 | Brother HL 5250DN Laser Printer
Wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Cannon imageclass mf5550 troubleshooting
The document feeder on this machine uses a separation and a feed roller ,the pad is on the bottom and the roller sits on top . in most cases the pad will be white if it is not it must be cleaned .use isopropyl alcohol. then clean the roller using water on a paper towel. On the tray issue if the paper is torn or nicked the sensor flag may be damaged if it is you will need a service call . if the paper is not nicked check to see if the default paper size has been programmed into the user settings on the copier [ read the owners man.] When you send a print to the printer go to printing preferences and check on the paper size being sent to the printer it must match the paper size loaded into the machine
Jan 02, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Fax Jam
hp tells me to do the following
does this help you ?
Issue While printing, copying, or receiving a fax, a paper jam occurs. If the jammed paper is removed incorrectly, other problems may occur. Clearing paper jams Remove the jammed paper by following the steps below: WARNING: Jammed paper must be removed using the rear access door to avoid mechanical damage. Do not remove jammed paper from the front of the all-in-one.
  1. Turn off the HP product and turn it so the back of the all-in-one faces you.
  2. Disconnect the power cord from the back of the all-in-one. CAUTION: The power cord must be disconnected to allow the paper feed rollers to turn freely and avoid mechanical damage.
  3. Locate and open the rear access door by pressing in on the left side tab to release the catches and then pulling the door toward you. Figure 1: Removing the rear access door c00100775.jpg
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord and turn on the all-in-one.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
richard from chicago
Dec 02, 2007 | HP Officejet 5510 All-In-One Thermal...
Samsung CLP 300 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
