Question about iLO 3200 32 in. LCD Television
No picture On my iLO TV, I can change channels, hear the programs, but my screen is blank, no picture. What can I try to correct this problem.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Change your inverter board
Posted on Sep 21, 2008
Fix blue screen av27870
Hi. Switch off (mains switch) the VCR. Then see if you can change channels with your TV remote. Blue screen mostly means that no channel has been programmed. If there is , you should at least have the sound. So, if you have sound, there is an internal problem in the TV. If no sound appears, try to get into setup mode (button Menu)
and programm your channels. I suppose there is signal on your normal areal connection. Check this out with another TV set, or use the tuner from you VRC. I know there are a lot of possibilities, but you can sort this out, step by step. Good luck.
Oct 18, 2014 | JVC Televison & Video
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Watching a TV program and during the program it just turned off. When turning back on TV, the light indicating that it's on but no picture not even static on the screen......just blank. Its a RCA Model...
Can you hear any audio? Look behind the TV, you should see some light emitted from a grill back there. If you hear audio and it appears you can change channels and what not, you lost at the very least your back light, which can be replaced , or worse the power supply to the back light which will cost you a bit more than the already expensive backlight.
Oct 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv stays black
Do you have audio and if so can you change channels to hear other programs? If so have a bad vertical IC. Have a tech turn up the screen control to see a white horizontal line. By your question I would say this will correct the problem.
Jul 26, 2009 | Sanyo DS27510 27" TV
Black screen on avol combo type tv. model #ALTD1902M
The degasuss circuit is staying on. There is a coil of wire wrapped around the picture tube. Uplug it. The picture may or may not remain in proper color. Take it in for repair to be safe.
Apr 13, 2009 | Televison & Video
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
32 in ILO tv, goes blank
Usually the blue screen is an indication that the video signal to the TV is not present. Most of the new TV's have a video input selection button on the TV and on the remote; try changing the video input selection.
Apr 27, 2007 | iLO 3200 32 in. LCD Television
Screen is black
Mar 10, 2007 | iLO 2600 Television
iLO 3200 32 in. LCD Television Logo
57 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
