Question about Garmin Rino 120 2-Way Radio
LED does not work
I dropped the Rino 120 and the screen now only turns a very dark blue but has no images. the radio other seems to work other than that. When I turn off the unit the screen goes back to the off color, and when turned back on only turns solid dark blue.
  • kinginc Sep 20, 2008
    When you say replacement do you mean just the LED or the enire unit?
    Brigadier General:
  • 5,158 Answers
You have damaged the screen and it will likely need replacement. there is one other possibility... you may have loosened a connector inside the radio... tap it gently with your finger to see if there are any changes in the display
Robert
Posted on Sep 20, 2008
  • Roberta Smith
    Roberta Smith Sep 20, 2008
    hate to say it... that becomes an issue with you... it may very well be cheaper to replace the unit (sad as that sounds) then repairing it. electronic items just don't take kindly to being dropped.... i had a customer bring me a laptop once that fell off his car... on the freeway.
    Robert
How come the garmin 120 radio isn't compatible with standard Motorola walkie talkies
When programmed to the same frequency and code settings the Garin Rino 120 should match the Motorola TalkAbout line of radios. They are all using the same UHF FRS/GMRS frequencies. Here is a link to the Garmin user guide where you will find the frequency charts on pgs. 100-102: http://www.uky.edu/~jmlhot2/courses/for480/Rino120_OwnersManual.pdf
Motorola TalkAbout user guides can be found at: http://shop.giantintl.com/Manuals.asp
Best regards.
Nov 20, 2014 | Garmin Rino 120 2-Way Radio
Keyboard locked out unlock keyboard
Google the instructions for the Rino model you own. On mine, once you turn it on, you press and hold the power button and it unlocks.
Sep 04, 2013 | Garmin Rino 120 2-Way Radio
Instruction
Download or view the .pdf Rino 120 Owner's Manual here........
http://www8.garmin.com/manuals/Rino120_OwnersManual.pdf
Dec 10, 2008 | Garmin Rino 120 2-Way Radio
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
Rino 120 - Disabled WAAS
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
Oct 04, 2008 | Garmin Rino 120 2-Way Radio
Turn it on - black screen
Dropped the rino 120 and the led is blank but radio works
Sep 01, 2008 | Garmin Rino 120 2-Way Radio
Rino 120 Send note
This sounds like the new firmware version may not work on the
older model.
The best solution would be to contact Garmin
Product support at (913) 397-8200 or 1-800-800-1020
Monday - Friday, 8am-5pmCDT or by email at sales@garmin.com
Pat
Aug 09, 2008 | Garmin Rino 120 2-Way Radio
Garmin 120 will not turn on
i talked with garmin tech today, he said to hold the button below talk, and the wheel and the power at the same time to master reset....it did not work for me but it might for someone else
Apr 03, 2008 | Garmin Rino 120 2-Way Radio
Broke rino
I had a similar problem with my account.
I pushed the one batteripolen down as it started up again.
Mar 12, 2008 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
153 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
