Question about Breville ESP8XL Espresso Machine
Exploding........ After two years of wonderful coffee the machie now explodes when I start the process. I have cleaned it extensively, but it will still do it MOST of the time. Suggestions? I hate to give up on it. Lorraine Cardoza
  • 3 more comments
  • desisto521 Oct 23, 2008
    The air pressure bursts out the basket, instead of having a drip through the coffee basket.
  • Roberto48 Nov 01, 2008
    It took mine a year of daily use to develop this problem. The cause is the deterioration of the rubber seal that the coffee wand (filter basket) sets against when screwed in. This should be a simple repair but to my consternation I can't find a source for this part. If I find a source, I will post.
  • tractor_girl Nov 02, 2008
    we have the same problem, even AFTER replacing the seal, it seems to happen randomly - after 1-4 cups, it explodes again. Have we not put the seal in properly? We think we have. The new seal looks identical to the old. Is there some other trick to putting in the new seal?
  • AussieNina Dec 01, 2008
    After two years of great make it yourself espresso my machine has come up with the same problem...could it be the silicone ring?? It looks intact...hmmm... I wonder why it's started to 'explode' like that...I don't what to give up on it!!
  • Anonymous Jan 15, 2009
    let me know when you find the answer
Hi All. I too was having this so called exploding issue with my machine & couldn't get any coffee!! The culprit is a clogged filter!! As you might know, Breville uses a double wall construction for the filter which incorporates an inner cup with many fine holes and there is only ONE small hole on the bottom of the outer wall(bottom). I guess over time some fine fine grounds get thru the inner layer and accumulate between the two layers and eventually get compacted enough to completely clog the filter to a point that the pump cannot push the water through it!! Thus the pressure from the pump can't escape & is releasd when you try to remove the coffee basket!! You can try to use a small pin inserted in the bottom hole to see if it clears the obstruction. It didn't work for me! I even tried using high pressure air to clear it, again unsuccessful!
THE FIX: Buy a new filter!
P.S. I found my machine to have some build up behind the strainer where the water enters the coffee chamber. To clean and clear, follow these steps: Unplugg the power cord!! Remove the watertank. Remove the filter holder. Turn the machine upside-down, Remove ONE screw in the center of the coffee chamber(It looks like a strainer with several holes). Remove the strainer and wash & clean any build up behind it. Reinstall in reverse order.
Posted on Jan 27, 2009
  • rsaintarnaud May 22, 2011
    Yes. That is the real problem with Breville : clogging of the ONE small hole on the bottom of the outer wall(bottom) of the filter.
    I solved the problem by cleaning the filter thoroughly by inserting a very fine needle in the small hole, and by boiling the filter in in a solution of vinegar for 15 minutes.
    To prevent future clogging by fine coffee particles, I put a piece of towel paper in the bottom of the filter before filling it with ground coffee. I use paper tissue folded in 8 that I cut as circular discs with scissors. This gives me 8 round paper filters.
    I have used this method for over 2 years now, and NO MORE CLOGGINGS!
    Raymond Saint-Arnaud
I wrote to Breville US via their website. They responded as follows: Replacement parts and products can be ordered online at www.brevilleusa.com. Simply find your particular model’s page, and click the link in the middle labeled “Find Replacement Parts for this Model”. It is called the “Steam Ring”. Please be advised that this is a part that needs replacement periodically. This part can wear out pre-maturely if the filter holder is put on too quickly as it wrenches the rubber seal, wearing it down. Also, please be careful not to pull the handle past the middle position as this also needlessly digs into the steam ring more than necessary. Resistance can be felt before the middle point if the filter holder is attached slowly. Thank you for your patience!
The Steam Rings are $4.00 each w free FedEx ground shipping (I ordered three!)
Posted on Jan 15, 2009
    Problem Solver:
  • 5 Answers
Yes. That is the real problem withBreville : clogging of the ONE small hole on the bottom of theouter wall(bottom) of the filter. I solved the problem by cleaning the filterthoroughly by inserting a very fine needle in the small hole, and by boilingthe filter in a solution of vinegar for 15 minutes, the filter being put upsidedown in a pot on the stove To prevent future clogging by fine coffeeparticles, I put a piece of towel paper in the bottom of the filter beforefilling it with ground coffee. I use paper tissue folded in 8 that I cut ascircular discs with scissors. This gives me 8 round paper filters. I have used this method for over 2 yearsnow, and NO MORE CLOGGINGS! Raymond Saint-Arnaud
Posted on Jan 11, 2012
    Problem Solver:
  • 11 Answers
I had the same problem, but it was not hte silicone ring, it was the plastic ring that holds the filter cup holder. it had a small crack in it so the filter was not firmly pushed against the silicone ring. i bought a new one from www.vancouverwireedm.com/caferomadiyt.htm and it fixed the problem.
Posted on Aug 13, 2010
I called Breville, and they are sending me a replacement gasket. No charge... FYI...
Posted on Nov 02, 2008
The Gourmet Depot has the gaskets that can be ordered.
Posted on Nov 01, 2008
  • 4 Answers
Can you define "explodes"...
Posted on Sep 26, 2008
Flashing dregdrawer and descaling lights
You need to run the descale process, which essentially cleans the plumbing.
Aug 19, 2012 | Saeco Odea Giro Plus Coffee Maker
K cup keeps exploding
Lower exit port is clogged. Clean as per manual pg. 18
Aug 07, 2012 | Keurig B60 Coffee Maker
Turned machine on - it went up to temperature - then it sort of "exploded" spraying water and from all sides of the machine - tripped the outlet fuse - I turn the steam knob and let all the pressure out. ...
Hi
That is the pressure relief valve blowing, and it can be scary. the problem is the pressurestat is sticking. You just need to replace the pressurestat. that controls the pressure in the boiler. You can adjust the to any pressure but the correct pressure is the light should go out at 1.1 on the gauge but the pressure will continue to about 1.2 on the gauge. If it hits 1.4 the pressure relief will blow. This is really a safety precaution to prevent the boiler from exploding, so don't try adjusting the relief valve.
Sep 14, 2010 | Pasquini Livia 90 Espresso Machine
Marzocco FB/80 exploding pucks
Check the shower screen and water flow. Press the brew button and watch how the water flows, is it a nice shower or a blob of water, is it in the middle of the screen or close to the edge. Also check the groups where they are connected to the boiler, if it is welded skip the bottom great, if not and there are gaskets, nuts and bolts, and water is flowing on the edge of the screen then it is possible that the diffuser gasket needs to be replaced.
May 14, 2010 | La Marzocco FB-80 Series 3 Groups Coffee...
Exploding filter holder
The discharge solenoid is not functioning properly or the tube is dirty, try backwashing the machine.
Jan 31, 2010 | Saeco Gran Crema Espresso Machine
Exploding capsules
Exploding capsule is caused by lack of FAP pressure. The reasons are a few: 1-machine leaking, 2-inf pump worn out, 3- 3way valve not working because of calcium buil up, 4-membrane assembly is broken, 5-labyrinth is clogged with calcium. Good luck
May 10, 2009 | Lavazza Espresso Point Capsule Machine
Cleaning
If you use white vinager like most will recommend, then just pour diluted vinager. Put no more than one to one ratio into the machine like you would water for coffee and let it process just like when you make coffee.
Mar 14, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Handle is pushed out
Are you using the pressurized filter baskets? My 2 1/2-year-old SL70 recently started doing the same thing, and I think I have narrowed the problem down to the filter basket (it works fine with a non-pressurized basket). I've ordered a new pressurized basket. I can't guarantee that this is the answer, but you might try it.
Feb 12, 2008 | Solis Crema SL-70 Espresso Machine
EXPLODING SAECO VIA VENETO
I think your machine is overheated, try to replace the thermostat on the boiler.
May 25, 2007 | Saeco VIA Veneto Espresso & Coffee Maker
Breville ESP8XL Espresso Machine Logo
467 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Ryan S
Ryan S
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
