Question about HP LaserJet 4250tn Printer
4250tn laserprinter i have a 4250 printer with 3 trays but the trays first say empty and when he drawer is opened and closed it at says trayxx is lifting but it does not lift. i have bought this as second user also if anyone knows where i can download the service manual.
  • khaledp Oct 28, 2008
    i have replaced tray lifter motor but it still did not work, i then found on a forum that it could be a paper jam, upon investigating i found a piece of torn paper in the paper path, when this was removed i now have perfect working printer with 3 trays,
    thanks for the manual without it i couldn't do anything
    regards
    khaled
  • 300 Answers
You can download it free of charge from http://www.eserviceinfo.com/equipment_mfg/HP_22.html the manual you want is LaserJet 4200-4300 Series which is near the bottom of the list
Posted on Sep 21, 2008
Need to perfrom nvram init on HP 4250
To initialize NVRAM, turn the printer power off. Remove any installed accessories (for example, a stapler/stacker). Turn the printer power on, and then hold down (SELECT button) when the memory count begins. Continue holding down until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. Press (UP ARROW button). Press the PAUSE/RESUME button (LJ 4200/4300) or the MENU button (LJ 4250/4350). The display should show SKIP DISK LOAD. Press (UP ARROW button) until NVRAM INIT is highlighted. Press (SELECT button) the printer initializes NVRAM and then continues its power-on sequence.
Nov 07, 2012 | HP Laserjet 4250dn Network Laser Printer...
Paper not pulling from tray 2 when tray 1 empties - Lexmark T654
For the majority of the Lexmark printers, all that needs to be done is to set the paper size and type the same for each drawer. Example - drawer 1 & 2 sizes are set to letter, drawer 1 & 2 paper types are set to plain. Set up this way, when drawer 1 empties, the printer will automatically switch to drawer 2 to supply the paper.
May 20, 2010 | Lexmark Office Equipment & Supplies
How to fit Duplexer unit HP 4250
Look at the back of the printer. Right above the back of the paper tray, there should be a piece of plastic that pulls out.. The duplexer slides into that gaping hole.
Oct 28, 2009 | HP LaserJet 4250tn Printer
13.20 error on tray 2 of HP4250
Paper in the back of printer where the duplexer is. Could also be the fuser is going bad.
Jul 23, 2009 | HP 4250 Monochrome LaserJet Printer
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
Paper drawer is stuck open
Please pull out the tray.
Check if the rear end fence is out of place.
If so, please remove the metal plate with the spring, remove the gear in the middle of the tray (below the metal plate) and reposition correctly in its place the rear and front end fences.
Then try closing the tray.
Good luck and please rate me, thanks.
Jan 27, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Tray 3 open or Empty
While tray 3 is detachable, when I remove it from my 2430dtn the printer won't display tray 3 options in any menus, so it looks like your printer recognizes that it is there.
The micro-switches that detect "open drawer" or "no paper" in tray 3 may be malfunctioning or the electrical connector built into the top of tray 3 may need cleaning.
(or, tray 3 may be out of paper <wink>)
Nov 19, 2007 | HP LaserJet 2430dtn Printer
HP LaserJet 4250tn Printer Logo
133 people viewed this question
Seeker5211
Seeker5211
