My Alpine CDM 7871 produces no sound other than through the pre-amp outputs. As as a result the only sound I am receiving is from the sub-woofers in the trunk. None of the speakers within the cabin of the car are producing sound.
  • 624 Answers
Your problem is the amplifier IC inside the unit. It is attached to the heat sink and soldered onto the main circuit board. If you have a soldering iron, solder, and solder wick (to remove solder from bad IC) you could do this repair pretty easy. You would need to disassemble the unit and remove the solder from the IC, then remove the IC from the heat sink and attach the new IC to the heat and put it back into the board and then solder all the pins of the new IC back onto the main board. After that, just put the unit back together just the way you took it apart. Just pay attention to where all the screws went and make sure you get them all back in the right places.
If you do not have the soldering equipment and are not comfortable with your soldering skills it would be better left to a service center to do this. Just about any service center would be able to do this repair for around $100. That should include the part and the labor. The price will depend on the service centers rates, but it is an easy repair that would require less than 1 hour of actual labor. Most shops will charge a minimum of 1 hour labor even if it only takes 15 minutes.
I have been repairing car audio equipment for over 18 years and can assure you that this is the problem you have, it is the typical symptoms for a bad amp IC.
Feel free to ask any other questions by just posting back on this thread.
Posted on Sep 20, 2008
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
Do you plug the sub woofer outputs to another amp?
Yes, for best results. Your subwoofer should have a seperate amplifier because it has low pass filter that produces low frequency signals. It is done by connecting the sub woofer output to the input signal of the amplifier and then connecting the output signal to the subwoofer speaker terminals. Hope this helps.
Jul 01, 2011 | Car Audio & Video
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
Feb 05, 2011 | Technics SA-EX500 Receiver
Hey I have an Alpine CDA-9851 CD Player and was wondering how to hook up my two 10" Kicker subs, since there is no subwoofer connection on the back of the player.
First to start you need an amp something that is a little stronger than your subs. What you want to do is 'T' off your speaker wires into RCA's to hook up into the amp. There is a device you can buy or you can cut some RCA cables. There are a few down sides to do it this way because as you turn up the volume the Subs will get louder and start to distort a lot faster than hooking up proper. The best way to do it is to get a deck with RCA sub outputs. Good Luck
Mar 25, 2010 | Alpine CDM-7874 CD Player
I would like know whether a sony xplod subwoofer can be connected to my alpine car audio system! xplod sub woofer is 1100 watts.
Deffinitely but wired directly would be pointless, the Alpine's internal amp is way to weak to get the best out of the sub. You need an amp, minimum 300w and bridge the outputs to give all the power to sub preferably switched to low-pass (most amps will have a high / low pass switch)
Dec 07, 2009 | Alpine CDA-7892 CD Player
Connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
Mar 20, 2009 | Alpine CDM-7874 CD Player
Pre set stations
Here's a link to the manual download page at Alpine. It should tell you everything you need to know.
Dec 05, 2008 | Alpine CDM-7835
No Sub Woofer Pre out output
I've got the same model and the pre out transistor needs to be replaced,
sometimes you can get it to work by unplugging the reciever and the pre out
then plug in the reciever and plug the pre out in a couple of times or so untill it comes on
or unplug the amp from the wall then plug in the pre out , turn on the reciever wait for sounds to come on then plug in the amp.
if that don't do it the pre out transistor needs to be replaced
Oct 16, 2008 | Pioneer VSX-D511 Receiver
Cdm alpine 7861
Make Sure the remote wire is connected from the radio to the amp, its normally a blue wire. Here is a picture of what the setup should look like.
Jul 27, 2007 | Alpine CDM-7861 CD Player
178 people viewed this question
