Swithced ic chips
but now there is no picture at all!! I desoldered the old ones and soldered in the new ones. I might have made a mistake in the picture snapping the black wires in the correct spot. You there are two black wires with a yellow piece at the end. One from the board and one from a black plastic tube labeled rfc-8 which i thought went to the back of the tv with the wire clipping on the side of the tv. I may be right with both of them but i am getting sound with absolutely no picture. THe menu box cant even appear. Help!!!
    Novelist:
    Champion:
  • 203 Answers
Those wires are ground wires they don't matter where you hook them up....there is a wire that comes off the trippler (the pice that hangs off the metal that holds the tubes and has the 4 big red wires plugged into it) and plugs into the deflection board is that plugged in?
Posted on Sep 21, 2008
Hi, my rear-projection TV (LG 56NZ23RB) initially had problem with convergence. I bought STK ICs, desoldered one and resoldered a newly bought IC. I tested it, but heard a chirping sound and would not...
There are several other components near the Convergence IC's that usually need replacing. These are fuses that look like resistors. There are also some resistors that can go bad also. You may have a solder bridge on some of the pins on the IC too. It's easy since the pins are so close to each other. Shopjimmy. com has repair kits that address your problem
Jan 28, 2014 | Televison & Video
During a storm a bit ago all the HDMI ports stopped working I am looking to fix them finally and wondering if anyone can help w a part # and instructions.
A basic understanding of electronics helps. I would look inside on the board and follow the traces from the hdmi back to the chip that feeds it. It would likely be an ic that has a voltage regulator in it as well as something to convert the serial port data. Write down the numbers on the chip and go to or phone an electronics parts supplier in your area and they will consult a cross reference manual to see if an after market version of the chip exists. If not they will order the original. Once you have the chip, you will need a decent soldering station ($100 or so) and a solder sucker. The solder sucker is used to desolder the chip or component slowly. Don\'t overheat the component but desolder as far as you can. then wiggle each leg one at a time until it breaks the remaining solder. If it does not wiggle off heat it again then wiggle it. Once all unsoldered gently pry out. (any other attempt to desolder without a solder sucker will damage the printed circuit traces) Before removing the ic verify which pin is pin 1. It may be printed on the board or a corner of the chip is marked somehow. Place the new chip in with pin 1 in the proper location. Use hitech solder that is hollow and contains flux on the inside to resolder. If the wrong solder is used the flux may attack the components and it will fail within a year (plus or minus). I would suggest finding someone who already does some electronics to assist you or to do the whole job.
Nov 18, 2013 | Panasonic Televison & Video
Power board has been replaced with a new one. Power light comes on and then just blinks. No picture or sound from the TV. This set belonged to my daugther and it just quit working. She got a new one and I...
Hi jblake4900,
First, please double check if the part/board no. (SSR-9010A-M2) is the same as the original one. If yes, then other parts gone bad also aside from the power supply board. This is caused by faulty convergence chips (STK394-250) on the deflection board (part no. SSR-2510A-M2). Your unit used two convergence chips that is mounted on the large aluminum heat sink behind the flyback transformer.
I would advice you to replace both the convergence chip.
You need to prepare the following :
1. Necessary tools and test instrument2. Soldering Iron3. Desoldering pump4. soldering lead5. Thermal paste.6. 2 pcs STK394-250
Soldering Tutorial
How to desolder parts on the board
Let the unit unplug from the outlet at least 1 hour to drain the voltages from the power supply board. Familiarize all connectors (take a picture of it if necessary to guide you replacing the connectors).
Please let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Jdvillanueva
Nov 21, 2011 | JVC AV48P777 Television
How can chang sony tv stk ic
if it is a sony check to see if any of those little green resistors are blown first. most sonys have the stk chips on the main deflection board.they will be next to each other with a big heat sink on each.have a soldering and desoldering iron ready as well as tape and marker for the wires.. remove the wires from the board you dont have to take the board all the way out. start desoldering each pin. if some pins are stuck just touch the pin with the iron. clean the heat sinks.apply themal paste to the new ics. put the new ics through the holes and start soldering. this part can be tricky. put the tip on the pin the solder will flow just quickly remove the solder then the iron 36 times and your done.
Sep 11, 2010 | Hitachi 43FWX20B 43" Rear Projection...
JVC AV-48WP30 , how to change convergence
First of all tools,requirement to do the work on the Convergence board to do changes the 2 STK convergence ICS and some or all it resistors.U have a soldering iron,desoldering pump or soldering wicks and solders?Don't?must buy to do desoldering and soldering?Tries Amazon.com to buy solders.Tries wesites like Tvrepairworld.com to buy the convergence kit to replaced ur self,and buy the soldering iron here it have the desoldering pump attach to the sodering iron it self.For video tutoring how to take out convergence board out of the tv and replacing the 2 STK covergence ICS and some or all it resistors.Might included in the buying of the convergence kit,not,Try You Tube type in convergence problems,will have video some body doing it.
Jun 07, 2010 | JVC AV-48WP30 48" Rear Projection...
Tv picture is slightly blurry, looks like the 3 colors are a little off alignment of each other. pic gets a little better after tv has been on for awhile. tried perfect focus, but doesnt help.
If the flash focus isn't doing anything you have bad convergence IC chips. This is a common problem with rear projection sets. The chips wear out from heat. You need new ones and they need to be replaced in pairs. The parts are not very expensive, the last set I did cost $38 for the pair on a Sony KP-57WS510. The repair requires some very tedious desoldering and soldering in the new ICs. If you have some experience with electronics and soldering it is not very hard. A shop will charge $300 and up for this repair. If you would like more details on this post a comment back here.
Dec 05, 2009 | Sony KP-57HW40 57" Rear Projection...
How do you replace ic chips on Panasonic 52 inch hdtv projection?
Most IC's on circuit boards these days are of the surface mount variety. You will need special Desoldering Equipment to remove these chips, especially the one wth 100 or more pins, the type of equipment used in this process heats all sides of the chip at once while a small suction that grabs the chip for removal. Now the SIP chips (Single inline package). chips which usually consists of less then 20pins can be removed with a desoldering gun such as the HAko 880 desoldering gun. Or you can use a standard soldering iron and solder Wick, that can be found at Radio Shack under Soldering Braide).. These procedures are common for all IC replacement. I am asuming you are trying to remove the Convergence IC on this model, The two large Black one labeled STK-392-110, the correct and easy way to remove these is to remove the entire board from the unit and remove the two screws holdinf each one in place, Unsolder the pins of each one and remove the IC, reverse this process to reinstall them. Good soldering technique is critical here as you don't want to bridge pins together causing yourself more problems. Double check your soldering and Double check it again.
Delhielectronics@live.com
Sep 28, 2009 | Panasonic PT-53WX53 53" Rear Projection...
TV Picture is distorted
Hi, common issue in your set, the convergence IC`s have failed, if your real proficient at soldering & un-soldering you can replace them, if not you need to call a tv tech, video-tek
Feb 02, 2009 | Philips 60PP9753 60" Rear Projection...
Convergence chip replacement. Part #STK-392-150
Hi.
You will need desoldering braid or wick to remove the old solder from legs of chips, Ensure no solder is sticking any of the legs to the pcb.
Once done remove screws or clip holding chip to heat sink & remove the chip. If chip is stuck to heat grip it with pliers & work it loose then remove.
Remember to put new heat sink compound on the backs of the new chips when fitting.
Oct 11, 2007 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
