Question about Maytag Washing Machines
Automatic temperature control
On my maytag model mav5758ewn, only hot water will fill tube no matter what water temperature I select on the automatic temperature control, any ideas as to the problem.
  • 116 Answers
The cold water valve may be defective - the solenoid (coil) burnt open. Coil may be replaced
Regards
Posted on Sep 20, 2008
I have a Maytag MAV7700 washer. It can fill with hot or cold water but when warm is selected it doesn't appropriately mix them to get a warm temperature even with the automatic temperature co
Hi etjacobsen.
As 'warm' is a mixture of 'hot' and 'cold' water a simple remedy to your problem might be to reduce the flow in the tap supplying the machine.
Good luck.
Nomess
Jan 12, 2015 | Maytag MAV7700 Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
Jan 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Washer is rinsing with hot wateer nomatter what temp. setting is used. I have tried to switch hoses twice now, no difference in rinse but now on correct wash temp.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
Apr 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hot water will not fill into the tank when starting cycle.
The ECU is at fault.
Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 44832 hot water won't stop.
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve Adefect in the water-inlet valve may mean that it's no longer able toshut off completely when the electricity has been turned off to it. Ifthis occurs, the valve may leak and drip water into the clothes tub. Intime, the water may accumulate substantially. If this happens, you needto replace the valve.
Water-level switch Adefect--or an obstruction--in the water-level switch may mean that itcan't tell the water to shut off. So the machine overflows. This switchsenses the water level in the clothes tub. It's usually a diaphragmdevice with a small, clear tube attached between the switch and thebottom of the washer's outer tub. As the water level in the tubincreases, the pressure on the air in the tube increases. When thepressure reaches a certain level, it activates the switch, shuts offthe water, and signals the timer to begin the agitate cycle. You caneither clear any obstruction in the tube or replace the water-levelswitch.
Aug 03, 2008 | Kenmore 44832 Front Load Washer
The water will not come out cold, it is warm or hot. This washer has an automatic temperature control button.
just a possibility but have you the hot and cold hoses the wrong way round assuming it is a two fill hose machine. way to check is to select rinse and put you hand in the water coming into the drawer. if it is warm, then hoses are wrong way round
Jun 29, 2008 | Maytag Washing Machines
Water temperature problem
Chief Walley, you have a temperature control board that sits right behind the timer. A thermistor senses the water and sends the info to this board. The thermistor sits at the water injector. The board may be your problem, I have seen many like this. Keep in mind that the target temp for cold is 75 degrees. If your incomming water is higher than this, you are going to get a warm fill, which they think is cold. Without being there, I would go after the board. Catriver...post back.
Aug 08, 2006 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
