Question about Garden
Long reach hedge trimmer
Just bought a Husqvarna 325HE4x long reach hedge trimmer online. Tried it today. The engine runs okay but when I open the throttle the cutter blades don't move at all. Being the weekend i can't get hold of the supplier!
Any idea what may be wrong?
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    does the engine start to bog when you increase the throttle or does rev out?
    Scholar:
  • 76 Answers
Try loosening the bolts up on the blades just enough to allow the washers to move freely a little, spray the blades down (but don't soak them ) with WD40 to lubricate the blades, that should solve it. If that doesn't do it then you may need to pull the gear housing cover off to see if something is jammed.
Posted on Jan 14, 2009
How do I put the blade back
Husqvarna Hedge Trimmers 122HD60
www.husqvarna.com/.../hedge-trimmers/122hd60/966...
Husqvarna GroupHusqvarna 122HD60 is a low noised and light weight hedge trimmer for domestic ... 23 inch. Weight. 10.8 lbs. Add to wish list Find a dealer near you. Manuals.
Oct 13, 2015 | Husqvarna 122HD60 Hedge Trimmer
Whats the fuel/oil mix ratio for unidentified hedge trimmer?
It's always better to have more oil than less. The high end trimmers like Stihl Husqvarna etc mostly take 50:1 ... The avg is 40:1 ... If you know the cc of the engine that's a good start, but even just going with a 50 to 1 ratio won't kill your unit, u may have some white smoke, light... that's okay, that's just the oil burning...if it's a low cc unit, just go with 40 to 1. Better safe than sorry.
Oct 02, 2015 | Garden
How do i adjust the carburetor on a husqvarna 18h hedge trimmer thanjs
you shouldnt need to,if it wont run right then your carb needs to be cleaned or gasline replaced,ethanol kills carbs and gaslines.
Apr 03, 2015 | Husqvarna Garden
Engine running, blades not moving
There is a big steel cable/wire type thing e in side the tube of the machine connect motor too head and itz broken look at small engine shop online
May 31, 2014 | Husqvarna 122HD60 Hedge Trimmer
Where do I get a new ignition coil for my 323L trimmer
Are you sure its the coil.? Have you tried relesing the fuel cap and trying it again.? Could possibly the fuel tank vent, creating vaccum in the tank and starving the engine.
Jun 28, 2012 | Husqvarna 323L
What oil mix ratio do i use for my huskvarna 123hd60
Husqvarna engines are made to tighter tolerances and are designed to run cooler. This is why the manufacturer recommends running a 50:1 mix. A richer mix of oil (such as 40:1) will run in the trimmer, but it will make alot of smoke, foul the spark plug, and clog the spark arrestor in a short period of time.
I recommend you stick with the 50:1 mix, and use Husqvarna, Stihl, or Echo 2 cycle mix. All three of these 2-cycle oils are a high grade oil designed to run in air cooled engines and they should not be substituted with cheaper brands
Feb 28, 2011 | Husqvarna 123HD60 22Inch 225cc 2Stroke Gas...
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Bought it today, it just stopped working. Worked beautifully for about 30 minutes. I would think something is caught in the blades, but that doesn't appear to be the case.
Check the blades very carefully! There can be a small twig, wire or most anything in there. Also, plug it into another extension cord to make sure the one you were using is okay. Good luck...Lee
May 29, 2010 | Black & Decker 3.8 AMP 22-Inch Electric...
Engine runs but blade doesnot
The clutch is not engaging or the linkage to the eccentric that moves the blade is not connected.
May 26, 2009 | Homelite Factory Reconditioned 26cc...
Garden Logo
868 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
