Question about Dell A940 All-In-One InkJet Printer
Hardware Error 0502
Yesterday, turned on printer to print one page. It printed the one, but then spewed forth 10 more blank pages. I turned off the computer. When turned it on again today, monitor said printer was busy. I told it to cancel printing several times, but nothing happened, message kept appearing. Then monitor told me to disconnect the connection on back of the printer. I did, and I turned off the computer,to no avail. I kept on trying, then looked at printer 'window' and saw "Hardware Error 0502." So then I googled 0502 and was directed to you.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
Spooling error
What make and model printer ?
There are a variety of reasons why a printer may feed a blank page through. This is, in some cases, an error. In other cases though it is a mistake in the page count or a simple matter of the printer trying to maintain itself.
Maintenance If a user has just loaded new paper into the printer or if an error message has recently been cleared the printer may run a blank page through.
Usually this is to make sure that the print path is now clear and that the next sheet it positioned correctly for printing.
Page Count
When a document is edited there is sometimes a blank sheet left at the end of the document. So, for example, if a 10 page document is edited down to nine pages, the computer and printer still sometimes read it as a 10-page document when a user hits the print key.
Page Separator
In some cases where a large number of documents are being printed, users may set a blank page separator.
This puts a blank page between copies of a document to show where one ends and the next begins.
A quick look at the printer's settings or control panel will tell you if this option has been turned on.
Fix a Printer Spool Error
When you send a job to your local or network printer, the print spooler is what keeps track of that job's location in the queue.
If the print spooler is not running, your job will not be able to reach the printer, so it is important to know how to resolve print spooler errors when they occur.
Click on the "Start" button and choose "Control Panel" from the menu.
Double-click the "Printers and Faxes" icon and locate your printer.
Double-click on the printer to get the list of jobs in the queue.
If you see any jobs in an error status, right-click on those jobs and choose "Cancel" from the menu.
Close the "Printers and Faxes" window and double-click on the "Administrative Tools" icon. Choose "Services" from the menu.
Scroll through the list until you see "Print Spooler," then right-click and choose "Start" from the drop-down list.
This restarts your print spooler and allow your jobs to print.
Right-click on "Print Spooler" again and choose "Properties" from the menu.
Go to the "Startup" option and set it to "Automatic."
This ensures that the print spooler starts each time your computer does.
Print spooler
http://social.technet.microsoft.com/Forums/en/itprovistaprinting/thread/cad5221a-d21b-4bf0-8e86-cacae254cb52
Apr 27, 2013 | Packard Bell Computers & Internet
Error message: HARDWARE PROBLEM ERROR CODE 0502 Only prints top part of page and then gives error code raabe@shaw.ca
Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the steps, contact Lexmark technical support for additional assistance. Thanks.
Jan 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
Receiving message Error 0502
hello
this should help
Lexmark printers with "Hardware Error 0502? Published on February 11, 2006 in hardware. 252 Comments Tags: 0502, error, fix, hardware, lexmark, printer. Good tip for the Lexmark All-in-one inkjet printer owners (mine is the X6170):
98393867_e286ea59ca_t.jpgAfter some months of use, your printer might get the habit of stopping in the middle of a page and showing "Hardware Error 0502" on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying.
The Lexmark support site will let you power off, remove the power cord for 30 seconds (!!), take out the cartridges and fiddle with some encoder strip. This whole procedure might take you up to 30 minutes and it will not help (been there, done that).
The real answer is given by a person called 'clem':
98393885_c4f82c99a9_m.jpgHardware Error: 0502.
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
Clem
(from fixyourownprinter.com)
This works! Clean the ****** with a paper towel (another page talks about re-lubricating the thing, but that was not necessary in my case). The towel will be black (ink residu, presumably), but there you go printing to your heart's desire again
Nov 30, 2010 | Office Equipment & Supplies
Printer displays hardware error 0502 wont print " HELP "
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
.... most of the time, it's the encoder strip that is giving the problem..
goto
http://support.lexmark.com/index?userlocale=EN_US&locale=EN&page=content&segment=SUPPORT&productCode=LEXMARK_X5150&id=HO2707
May 24, 2010 | Lexmark X5150 All-In-One InkJet Printer
What is a hardware error 0502
98393867_e286ea59ca_t.jpgAfter some months of use, your printer might get the habit of stopping in the middle of a page and showing “Hardware Error 0502” on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying.
The real answer is given by a person called ‘clem’:
Clem
This works! Clean the ****** with a paper towel (another page talks about re-lubricating the thing, but that was not necessary in my case). The towel will be black (ink residu, presumably), but there you go printing to your heart’s desire again.
Jan 26, 2010 | Lexmark X5150 All-In-One InkJet Printer
What is a Hardware Error 0502?
There is a shiny steel bar inside the printer, and the ink cartridges move up and down this bar to print on the page. If this bar gets gunked up from stray ink or paper dust, then the motor strains to move the print heads back and forth, and you get this error.
Fixing it is simple. Take some kleenex, and with power unplugged, clean the bar very well. Then Spray some WD-40 on a Kleenex, and lubricate the bar by wiping the WD-40 kleenex on the bar.
If this helps, be sure to hit the "thumbs-up" for me!
Dec 27, 2009 | Dell A960 All-In-One InkJet Printer
How do i fix hardware error 0502 on my dell printer model # A940
Dec 14, 2009 | Dell A940 All-In-One InkJet Printer
Printer problem for a dell 924 printer
I have run across several Dell & Lexmark printers that after a while of working great, decide to have an "issue"... If you are printing more than 1 page, they will print the first page, then stop. The computer says "Cartridge Stall" and the printer says "Hardware Error 0502" or something similar, depending on the printer... Anyway, the message on the computer suggests making sure your cartridges are installed correctly, and nothing is blocking their path... After dealing with this many times, I have finally found a solution that seems to work!
There is usually a metal bar that the cartridges slide back and forth on... over time, this bar can become "gunked up"... Use alcohol pads to clean up the bar, and the surrounding area.... Clean out as much of the track as you can also. Tada... .No more cartridge stall!!
Oct 22, 2009 | Dell A940 All-In-One InkJet Printer
Printing error says: Hardware error 0502 (?)
he real answer is given by a person called ‘clem’: 98393885_c4f82c99a9_m.jpgHardware Error: 0502.
Clem
Jul 12, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X6170 printer shows hardware error 0502 when printing
On the multi function machine there seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
You may have to do this from time to time if the error keep reoccurring.
Mar 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
107 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
