Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Kenmore washing machine
I have been getting "circle" stains on my clothing. I assume that the inside of my machine needs cleaning????? The circles on the clothing match the circles on the inside of the maching.
PLEASE HELP. manual doesnt address this.
  • 126 Answers
YOUR ASSUMPTION IS CORRECT THAT IS CAUSED BY THE DIRT BETWEEN THE DRUMS.THE EASIEST WAY TO CLEAN THAT IS TO FILL THE MACHINE WITH BOILING HOT WATER AND LET IT SOAK FOR THREE HOURS.THEREAFTER START THE MACHINE ON THE SHORTEST WASH PROGRAM AND LET IT WASH OUT.DONT USE ANY DETERGENTS OR CLEANER.ALSO BEST YOU DO THAT EVERY THREE MONTHS TO AVOID IT FROM HAPPENING AGAIN.
GOOD LUCK.AND PLEASE RATE THE SERVICE
MOHAMED
Posted on Sep 20, 2008
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
My clothes still wet after complete circle (done)
There is a problem with the drier in ur washing machine... if it is old try to change it or try for service...!!!!!! But the fact is that there will be 10% moisture in ur clothes after the machine wash...!!!
Mar 22, 2012 | Kenmore Washing Machines
HOW DO I GET THE SYICKY CIRCLE OFF MY WINOW?
I assume you mean "sticky" circle. I usually recommend a product called goo gone. And use a cloth wash cloth, not a paper towel. hope this helps.
Aug 25, 2011 | Car Audio & Video
Why does my washing comes out with stains on it.... they weren't there when it went into the wash...
yes sometimes ink pens can be washed when we are not aware it was in someones pocket. I use straight ammonia and a cloth to clean my washing machine drum a couple times a year because these things have happened to me before. The ammonia will cut the grime and pen stains out of the drum. Then take a squirt bottle and fill it with white vinegar and squirt all around inside the drum of the machine. Run a wash without any clothes with the hottest water to clean the drum and clear out the stains. Do this to the dryer also and clean out the filters. Take the dispensers out from the washing machine and clean those too and your cleaning is done for a while. Apparently the ink has been in the drum of your washing machine and putting the color into your clothes. You can bleach out the white clothes that turned blue. Use the stain remover for colored clothes. Hope this will help you.
Feb 01, 2011 | Whirlpool Washing Machines
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore Washing Machines
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Dark spots on my clean clothes
do you use a lot of fabric softner? If you do this might be your problem try to change soaps and stop useing fabric softner. try useing powder detergent and make sure that it is HE. let me know how it goes thanks
Jun 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
DARK CLOTHES END UP WITH BLEACH DOT STAINS
SOME BLEACH DISPENSERS USE COLD WATER TO FLUSH THE BLEACH FROM THE CUP. CHECK THE COLD WATER FOR GOOD PRESSURE. IF THERE ISN'T GOOD PRESSURE, REMOVE THE COLD WATER HOSE FROM THE MACHINE AND CHECK THE SCREEN INSIDE THE VALVE WHERE YOU REMOVED THE HOSE. PUT THE END OF THE HOSE IN THE TUB AND TURN IT ON. CHECK FOR GOOD PRESSURE. CLEAN THE SCREEN AND RECHECK THE WATER PRESSURE AFTER REINSTALLING THE HOSE AND TURNING ON THE WATER. IF YOU STIL HAVE POOR PRESSURE REPLACE THE VALVE.
Apr 07, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
