My printer will not communicate with my laptop, I have tried re installing the software, but this does not work I get a message saying port not found
  • stebec Sep 21, 2008
    Hi
    My printer is a canon Mp610, operating system is vista home premium, the laptop i have is toshiba p200d satellite.
    My problem is I cannot load my software for my printer, the printer was working fine last week, then all of a sudden i kept getting a message saying printer is offline, i check all the cables and the were all connected. I decided to un install my software then re install it, It installs so far until it gets to installing the MP drivers, I get a message saying cannot find port.
    If I go into control panel and open my printer all that is there is microsoft XPS document writer, which I have not got a clue where it has come from. If I click add printer I get a message saying cannot perform task.
    Hope this helps
    Steve
  • steve shroder May 11, 2010
    how about some specifics like model numbers, operating sytem, interface types, anything that may shed light on the technical aspects of your problem. your post is very vague.
  • 141 Answers
It sounds as though you have blocked permissions. Is this your personal pc or a company machine? if it is a company machine then you need to interface with your network administrator to resolve your issue.
If it is your personal pc, then you must log on as the administrator to perform this installation, and i would also advise you to go to your printer manufacturer's web site and get the latest vista drivers. Vista is still relatively new and new drivers are popping up everyday. Good luck!
Posted on Sep 23, 2008
Communication error
2 possible probs on this depends on if you are using Wireless or cable If wireless it basically means that your laptop or desktop computer is not receiving instructions from printer and thats why there is a communication error coming up, try just testing wireless port on another laptop to see if its a fault with the one you have,
If its a Usb cable issue try reconnecting in another Usb port sometimes some ports are usb 2.0 or 3.0 and will not be powerful enough for your printer, In addition try using another cable it could be faulty also printer cables are sometimes similar to scanner cables swap them round this depends on the male fitting though if they are the same,
another method is disconnect printer from computer and run a self diagnostic on its own to see if its working alright if ok reconnect but before you do make sure your computer is up and running first with Usb it cable plug and play which means your computer should recognise it and install software required if a disk is required make sure thats ready
Or could be something real simple like your usb or connector is not connected correctly take them out clean and put back in reboot and retry
hope this helps
Aug 12, 2014 | Epson Office Equipment & Supplies
CANT ENABLE BIDIRECTIONAL COMMUNICATION X4550
I have tried to set up this wireless printer on my laptop (windows vista basic). I run through installation and get message - installation complete and the green indicator light is fully on. When I try and print I get message Printer cannot communicate with computer - please turn on 'Enable Biodirectional Communication' in printer properties. I go to control panel/printer/propertie/ports/ and I see Enable Biodirectional communication - the box is grayed out and I cannot enable it. Any suggestions?
Jan 22, 2010 | Lexmark X4550 InkJet Printer
Printer cannot communicate with the computer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Sep 10, 2008 | Lexmark Z735 InkJet Printer
Unable to print
To fix a fouled install :
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
I cannot connect a dell 720 printer to dell laptop Inspiron 1501 (Vista). It says it is installed but a message comes up that communication is not available.
First, shut down your computer and priner. Unplug both from the wall outlet, Unplug the printer from the computers USB receptical. Next, plug both the computer and printer back into the wall, and turn on ONLY THE COMPUTER. After the computer is fully initialized, plug the printer into the computer's USB socket and turn printer on. A small window on your screen should say:NEW HARDWARE FOUND. it will ask if you want it installed, click on YES. and just follow the onscreen instructions, and make sure your printer driver is compatible with VISTA..To check, go to http://support.dell.com and left click on WINDOWS VISTA SUPPORT. Left click on LATEST VISTA DRIVER UPDATES, and follow the onscreen instructions to check what you have now, and what you may have to download.. If, after downloading and installing VISTA COMPATIBLE SOFTWARE,you still get the communication message, try this: On the windows screen, left click on START. left click on CONTROL PANEL, then left click on PRINTERS. Find your Dell printer icon and RIGHT CLICK on the icon.. On the drop down menu, left click on PROPERTIES. On the Properties window, left click on the PORTS tab. Make sure USB VIRTUAL PRINTER PORT FOR DELL is checked. If no, select that port, left click on the check box, also check ENABLE BIDIRECTIONAL SUPPORT and ENABLE PRINT SPOOLING boxes. Then left click on APPLY, then Ok. The Dell printer icon should show READY. Try a test print to check operation.
Aug 11, 2008 | Office Equipment & Supplies
Installing printer
Hi there!
1. Try another USB port at the laptop (if you have other USB ports in it).
2. Try a known working USB cable.
3. Try a different laptop/ computer.
This should further isolate your problem.
Hope this helps!
May 04, 2008 | Acer Aspire 5100 Notebook
Lexmark Z645 Printer
i have a problem of Lexmark Z645 Printer i want a software of this .
Feb 09, 2008 | Lexmark Z645 InkJet Photo Printer
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
154 people viewed this question
jasbo
jasbo
