Maybe. If you have a home network, then you can SHARE a CD drive on a desktop with the netbook.
Also,consider:
Many laptop vendors put a special restore partition on the disk.
At boot up, you should see a brief black and white message that says hit F? for boot sequence.
At that next screen will be an option to restore you computer.
Be aware, you are going to loose anything you have done since you bought the computer, think data, settings, pictures, etc.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Switch ON the PC, boot the PC
in 'Safe Mode' by continuously tapping F8 button after you switch On until you
get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are
facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot your problem should be resolved.
1. Open the Start Menu.
A)
Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A)
Click on the Recovery icon.
B) Click on the Open System
Restore button.
A
'System Restore' window will appear. Here you will have to check "Restore
A)
Click on the Next button
Now
you will find a window with Dates, Description and Type,
Note:
It is better if you could remember from which date you are facing the issue,
The
detail of that particular date should show "System Checkpoint" and
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
