This problem should be removed because:
Problem with Maytag Refrigerators
Maytag side by side msd 2656, ice cubes melts & refreezes
Solutions (1)
Best Solution
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Ice cubes melting then refreezing in clumps
I'm not having problems with the ice maker generating ice cubes. Instead after the ice cubes drop, they appear to melt somewhat, then...
Ice Maker Stopped Making Ice & Cubes are...
We've been noticing that our water dispenser has been acting up (sometimes it works and sometimes not). Now, I just noticed that our ice...
bottom freezer, ice cubes melting and refreezing.
amana refrig bottom freezer, ice cubes melting and refreezing. starter was replace about 1 year ago. arb2259cw
Ice-maker thawing-refreezing into block of ice
Ice-maker thawing - refreezing into block Our 18 year old side-by-side Sub-Zero has this problem about once a week: Makes ice cubes that...
Symptoms: Ice cubes melt, drip then refreeze...
Symptoms: Ice cubes melt and drip then refreeze causing ice-cicles. Looks to me that the defrost cycle is on too long? GE Profile Side by...
Add Your Solution
the green power light will not come on and every...
Other than that the freezer works I think properly, I cant seem to adjust the setting onit. Do you still have...
where is access to defrost coil
I wish to check the defrost coil and the defrost controls
sharp SJ-41F9W
refrgerator not working, freezer working
Fridgidaire refrigerater dispenses water
I have a Fridgidaire FRS26KF7A, manuf 05/01. a few weeks ago the water dispenser in the freezer door started to drip,...
Fix-O-Meter
64
64 people viewed this problem
- 1 person found this problem to be helpful.
- 2 people are following this problem
Top Maytag Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
