Vista installation i have window xp on my 'c, drive which has only 2 gb space left.my d has only 5 gb left out 80 gb sata hdd. now i am installing new window vista on my 2nd hdd which has 250 gb space, but after few steps it asks for drivers which are not in my cd. how should i continue
    Sergeant:
    Champion:
  • 258 Answers
Try updating the os using windows update
Posted on Sep 20, 2008
I cant istal win xp
hello,
1st go to ur bios and change SATA Mode to AHCI from IDE
then try install win xp again :D
Dec 05, 2013 | Lenovo 7479A6U - Thinkcentre M58P 7479A6U...
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
Windows xp installation problem
You might need to use the "Floppy" version of the Driver upon install (if you know what the chipsets are. Most likely it's Intel and you can slip stream the driver files into a new XP CD.
However if a partition is formated from Vista and you attempt to install XP over it without formatting it, crash is almost certain - XP and Vista have different versions of NTFS.
If you want both XP and Vista on the same machine, ALWAYS install the older one first! i.e. XP first. And create only 1 partition in XP where you intend to install on.
Then install Vista afterwards with Vista created partition.
May 23, 2009 | EliteGroup RC410L/800-M2 (V1.0)...
Sata hdd not Detect
To install Windows XP on SATA or advanced IDE hard drive, you will need to insert a driver diskette at the time of starting the installation process and pressing "F6". For more details visit the link below:
http://ufixitnow.blogspot.com/2009/04/oem-driver-support-during-windows-xp.html
Apr 09, 2009 | Microsoft Windows Xp Home Edition Sp2...
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Samsung 200gb hdd
When u bought a new hdd, it shud not have any partition on it. but in ur case, I assume u have formatted it to ntfs but no operating system is installed in it.
If u want to make the new hdd as slave and have another old hdd as primary, that have already an operating system installed in it, then the problem shud be hdd boot priority in bios. Enter ur bios and check for hdd boot priority and put the old hdd to the top most order, then restart. this shud fix the problem.
If u installed OS in ur new hdd (win xp),
1) ntldr or ntdetect.com is missing on root dir. (c:\). If u have another computer that works and have xp installed, just put this new hdd along with the current hdd and boot to windows. Copy ntldr and ntdetect.com to your new hdd. Or another way is just repair using windows xp boot cd.
2)the windows partition is not set 'active'. to set active, boot into winxp setup and press 'r'. this will lead to recovery console. type ur passwrod for admin (def=none). use diskpart command to set active. for easy way, put the new hdd to another computer. boot to windows. rightclick my computer, choose manage. on left pane select disk manager. rightclick on ur partition, then set active.
Hope this help
May 08, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Help me ! Lacie ED Disk Ethernet 10/100
if you are using (sata)harddrive dont install windows 98.i have a solution now before connecting your harddrive change the jumper to the slave (for single harddrive and single cd-rom or combo drive).it will work.plz install windows xp (service pack 2) or windows vista these are good versions for all!
Dec 07, 2007 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
75 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
