Question about HP Photosmart C4180 All-In-One InkJet Printer
Won't scan or copy
My printer prints fine, it has just stopped scanning or copying. It will begin the job, but the printer screen will read 'scanning' or 'copying' indefinately and the job will never complete. Then I can't cancel the job, or turn off the printer, so I have to unplug it to reset it.
Please help if possible.
Thanks!
  • alira Sep 20, 2008
    Thank you for the answer, but I forgot to mention I have a Mac OSX version10.5.4 so couldn't follow these instructions. Any advice for Mac?
    Thankx
  • 2,071 Answers
Solution
These errors are usually caused by a failed scan, a bad installation, communication problems or software conflicts. Follow the steps below until the problem is corrected.
Step one: Restart the computer
Close all programs and restart the computer. A required task might have stopped running or the system resources might have decreased due to tasks left running. Restarting the computer will refresh all Windows tasks as well as increase the available system resources.
Step two: Check for the correct entries in the Device Manager
Verify that the unit was installed on a DOT4 virtual port in the Device Manager.
  1. Right-click My Computer , and then click Properties .
  2. Click the Device Manager tab. (In Windows 2000 and XP, click the Hardware tab , and then click Device Manager .)
Check the list of installed devices for references to DOT4. If there are no DOT4 references, the software has not installed correctly.
If any of these entries are missing, the software did not install properly. Review the information in the HP document Troubleshooting Installation Issues for USB-Connected HP All-in-One Products in Microsoft(R) Windows (bpu01858) for installation assistance.
Step three: Check for communication problems between the all-in-one and the computer
Communication might have failed between the all-in-one and the computer. Review the information in the HP document USB Connected HP All-in-One's Software Reports a Disconnected or an Error Status (bpu01859) to check for communications problems between the HP all-in-one and the computer.
Step four: Check the computer to see if it is infected with a computer virus
If the all-in-one prints but will not scan correctly and does not show any symptoms of communications problems, the computer might be infected with a virus. Some viruses try to disable virus scanning software and in doing so disable scanning from the all-in-one. The following are symptoms a virus problem:
  • The scanning software works after installing the all-in-one software until the first time the computer is restarted.
  • In the Device Manager, opening the Properties of the Imaging Device entry will reveal a status of "code 19" or "code 28".
  • A Scanner Cannot be initialized error occurs. While this error may other reasons, a virus will cause this error.
When the all-in-one is turned on and connected, follow the steps below to see if this is the problem:
  1. Right-click My Computer (click Start first in Windows XP) and then click Properties .
  2. Open the Device Manager:
    • Windows 98 and Me: Select the Device Manager tab.
    • Windows 2000 and XP: Select the Hardware tab, and then click Device Manager .
  3. Locate the Imaging Device entry and click the plus (+) beside it. It may have an exclamation mark beside it.
  4. Right-click the all-in-one entry under Imaging Devices, and then click Properties .
  5. A Properties screen will open. Look at the Device status section.
Hope it may helps;.
Regards, VOTIT
Posted on Sep 20, 2008
Laserjet cm1017
Will it make a copy?
Do you get an error message?
Mar 18, 2014 | HP Office Equipment & Supplies
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
My printer scans, copy but won't print from computer?
Did you set this printer as the default printer? To do this go to Start - Printer and Faxes, right click on HP printer, select Set As Default Printer. If you are not see your HP Deskject F340 there, that mean your printer driver is not installed. Please install your printer driver.
If you already set it as the default and it is still not printing. Restart your computer to try solve problem.
You said that printer scans so the connection between your computer and printer is fine. Problem is your computer doesn't take the printer as it's printer device yet.
Hope this will help. Thanks for reading
Jul 19, 2011 | HP Deskjet F340 All-In-One Printer
I can't copy or scan. Printing works fine. When asked to copy , the display says copy in progress but nothing is happening. The same is true when trying to scan the display says scanning in progress but...
Did you try to scan from ADF or Flatbed glass?
Now as its not copying then it can be hardware issue so we can try to reset the printer and for that
1. Unplug the power cord from the back of the printer while the printer is ON
2. Hold and press the # and 6 key at the same time and while holding them plug in the power cord you will say that the printer turns On and there may be reset message on the screen of the printer ..release the buttons
its around 2 minutes process and it will reset your printer
If does not help then please get back to me
Apr 08, 2011 | HP Officejet 5610 All-In-One InkJet...
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
Not scanning
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X2500) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 08, 2009 | Lexmark X2500 All-In-One Printer
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
HP Photosmart C4180 All-In-One InkJet Printer Logo
474 people viewed this question
Seeker5211
Seeker5211
