Question about Nokia 3120 Cellular Phone
Hanging my cll is haging in between again n again. i reoeir it twice frm shop. now what can i do.
  • 2,071 Answers
Your cellphone needs software to re flashing,so it will not hang again.
Hope it may help you;
Regards,
VOTIT
Posted on Sep 20, 2008
Why is the screen frozen?
If you can't turn it of, leave it till battery discharges. Charge it again. If still haged up, take it to a repair service
Apr 11, 2015 | Amazon Kindle Paperwhite
Kenmore Elite washer service code CLL SrU
Re: Kenmore Elite 417; error CLL SRV We have well water and I think my error message and locked door were because the machine was trying to plump water and not getting any. I heard the error beeping and sent to check it out. There was another noise that didn't stop even after unplugging the washer, although the beeping did, which finally stopped after I turned off the water valves. Press and Hold the power button down to unlock the door and retry. If you still have trouble, call for service.
Sep 25, 2012 | Washing Machines
Its hang after window starts
Hi Rakesh,
Try pressing Ctl > Alt >Del and see what happens.Solved?
  • Remove the hard disk and re-fix it again.Try booting now.Solved?
  • Then your Operating System may have crashed!Remove the hard disk and enslave it on another machine with a good Operating System as a secondary storage device and reboot this machine.
  • On start up,press F1 to accept runnig unnix and the damaged files on your drive will be repaired.Remove it and install it on your machine.
  • Now try booting your machine.
Hope this helps.Thanks!
Please vote answer if helpful.
Dec 20, 2011 | ASUS S478 VIA P4V533-MX Motherboard
In my phone nokia 6233 a message will haged it . I cannot restore or Delete out box message . my phone 1,4,7,* keys was also not work . how can i restore it
Some of the hand-set like x2-01, x3 etc. can't delete dial number. But regarding your message hang means it's a software problem. If you had changed your SIM card meansRegarding your no 1,4,7,* keys not functioning means Change your keypad IC The best way is go to the nearest Mobile service centre.
Thanks for Using FixYa All the Best!
Aug 05, 2011 | Nokia 6233 Cellular Phone
I installed the software for a netgear WG111v3 and it hangs
redo the driver first remove the program and restart the pc then start again this normaly helps in 90%of cases hope this helps you
Mar 17, 2010 | NetGear WG111 802.11g/b Wireless Adapter
Hey i have a 1990 geo storm thats alittle tore up their is a house haging down from from the radiator fan that has been severd could anyone tell me where this house is supposed to go its small not even 1/4...
Hmm if it is a mouse house you can just throw it in the garbage.
radiator fans are not supposed to have any hoses hanging from them. radiators sometimes have a overflow hose hanging from them and thats normal. Sometimes, most of the time, the over flow hose goes to an overflow container. some people throw those away and let the hose hang. Probably not a good idea.
Mar 09, 2010 | 1990 Geo Storm
Software for call recorder
dear its income speaker frequency has been disturbed u must have to check the repair shop...or otherwise press behind the cll phone the voice will b clear..
May 28, 2009 | Nokia N80 Cellular Phone
I want circularlinklist program in c++
This C++ program is to perform the following operations
on a circular linked list
1)insertion
2)forward traversal
3)reverse traversal
4)search
->node structure :
a node contains
1) integer data
2) pointer to next node
-> This program works in microsoft VC++ environment
in windows xp
-> This program uses the following header files
1)iostream.h
#include<iostream.h>
class cll
private:
int data;
cll *next;
public:
cll* insert_one(int,cll*);
cll* delete_one(int,cll*);
void ftraverse(cll*);
void rtraverse(cll*);
void search(int,cll*);
void function();
cll*hd;
void cll::function()
cout<<”******************************************\n”;
cout<<”program to implement a circular linked list \n”;
cll * head;
head=NULL;
cout<<”\n\nMENU :\n”;
cout<<”1)insertion\n”
<<”2forward traversal\n”
<<”3)reverse traversal\n”
<<”4)search\n”
<<”5)exit\n\n”;
cout<<”Enter your option :”;
int opt;
cin>>opt;
int d;
while(opt!=5)
switch(opt)
case 1:
cout<<”Enter data to the node :”;
cin>>d;
head=insert_one(d,head);
cout<<”inserted\n”;
break;
case 2:
cout<<”The forward traversal is :\n”;
ftraverse(head);
break;
case 3:
cout<<”The reverse traversal is :\n”;
hd=head;
rtraverse(head);
cout<<”NULL\n”;
break;
case 4:
cout<<”Enter the element to be searched :”;
int d;
cin>>d;
search(d,head);
break;
case 5:
break;
default:
cout<<”invalid option”;
break;
<<”2)forward traversal\n”
<<”4)search\n”
<<”5)exit\n\n”;
cin>>opt;
cll* cll::insert_one(int d,cll* c)
cll*NEW;
NEW=new cll;
NEW->data=d;
NEW->next=NULL;
if(c==NULL)
c=NEW;
c->next=c;
else
cll*c1=c;
while(c1->next!=c)
c1=c1->next;
c1->next=NEW;
NEW->next=c;
return c;
void cll::ftraverse(cll* c)
if(c==NULL)
cout<<”\nlist empty\n”;
return;
else
cll *c1=c;
cout<<c1->data<<”->”;
c1=c1->next;
while(c1!=c)
c1=c1->next;
cout<<”NULL\n”;
void cll::rtraverse(cll* c)
if(c->next==hd)
cout<<c->data<<”->”;
return;
else
rtraverse(c->next);
void cll::search(int d,cll* c)
cll*c1=c;
if(c==NULL)
return;
else
if(c->data == d)
cout<<”found\n”;
return ;
while(c->next !=c1)
if(c->data==d)
cout<<”found\n”;
return ;
c=c->next;
if(c->data ==d)
cout<<”found\n”;
return ;
cout<<” search unsuccess ful \n”;
void main()
cll list;
list.function();
Mar 05, 2009 | Computers & Internet
Nokia 3120 Cellular Phone Logo
64 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
